Cisco 300SF Switch Configuration Problem with NAT Router
t.marksteiner1
hi,
i want to build a small network with following structure:
  • Internet Gateway
    • NAT Router (Router 1)
      • Layer 3 Switch (Switch 1)
        • vlan 1 to vlan 5
      • Layer 2 Switch (Switch 2)
So for testing, i replaced the internet gateway with a normal NAT router (router 0) with ip 192.168.0.254.
detail structure of vlans:
  • vlan 5
    • Router 1 with ip 192.168.5.254
    • Layer 3 Switch with ip 192.168.5.253
  • vlan 1
    • Switch Layer (Switch 2) with ip 192.168.1.252
    • Layer 3 Switch with ip 192.168.1.253
structure of 192.168.0.0:
  • NAT-Router (Router 0) 192.168.0.254
  • NAT-Router (Router 1) 192.168.0.240
I added a static route for 192.168.0.0 to Switch 1 with next hop 192.168.5.254 and a static route to Router 1 for 192.168.1.0 with next hop 192.168.5.253.
Now i tried following pings:
  • Router-0 192.168.0.254 from Switch 1 with vlan 5 interface (192.168.5.253) => works
  • Router-1 192.168.5.254 from Switch 1 with vlan 1 interface (192.168.1.253). => works
  • Router-1 192.168.0.240 from Switch 1 with vlan 1 interface (192.168.1.253) => works
  • Router-0 192.168.0.254 from Switch 1 with vlan 1 interface (192.168.1.253) => DOES NOT WORK
Router 1 is connected to Switch 1 by access port for vlan 5.
What is wrong with my configuration?
How can i analyze the network problem?
I hope anyone can help me.
Thanks for your reply and sorry for my late answer.
I found my fault. I thought that every NAT router is enable to provide NAT feature for multiple subnets, but this is not correct.
So i have to replace my Router 1.
Thomas
Aleksandra Dargiel
It looks to me like your L2 switch have  no default gateway configured? Have you done any ping test from the L2 switch?
Aleksandra
Thomas
