SG300-20 LAG issues
TwiztedTD
Hello everyone, I have two switches, SG300-20 and SRW224G4P
At first I only had the SRW switch and had all my workstations and servers connected to it.  I installed the new SG300-20 a few weeks ago.
I have all my servers connected to the SG300-20 gigabit ports and then all my workstations connected to the SRW switch.
Users have been complaining of slowness since the new switch.
If I plug users into the SG300 switch they noticed a defenite speed increase.
I have been trying to set up LAG between both switches but have had no luck.
On the SG300 I will disable auto negotiation on the two ports I want to use for the LAG.
I will then configure the LAG to use those two ports.  And I have tried with Auto Negotation both on and off the LAG.
Once I set up the LAG and have both network cables plugged in, I will start to get packet drops when pinging a server.  I noticed this when pinging from the SRW switch and while on the SG300 switch.
I then configured LAG on the SRW to see if that would make a difference and had the same results.
Does anyone have any suggestions?
0 Replies 0
