01-22-2012 06:55 PM
I have several SG300-10 and SF302-08P switches running with L2-mode, and after I upgraded their firmware to 1.1.2.0, they began to record the following logs every one hour.
- Severity: Warning
- Description: %COPY-W-TRAP: The mirror-config file is illegal due to failure of previous copy operation/s to mirror-config.
Also I found that I didn't see the Mirror Configuration file on the Configuration File Table in the Configuration Files Properties page.
I have had no problem so far but I don't think I can leave this situation as it is. Can someone give me any advice what I need to do, please?
04-23-2012 02:45 AM
Hi Akio,
I have the same issue on a SG300-28 upgraded to firmware 1.1.2.0.
Any advice from you or Cisco ?
Many thanks
04-23-2012 06:40 AM
Hello all,
Can one or both of you call into the support center at 1-866-606-1866 and create a case, so we can better support this issue. We are interested in finding a quick solution for your problem, but we need to gather the information, so we can resolve this problem.
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
04-23-2012 04:07 PM
Hello Randy,
I would like to contact the support center by e-mail instead of phone if it's possible.
04-24-2012 10:50 AM
Hello Akio,
We have a chat option that allows for real time support.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Randy Manthey
04-25-2012 12:57 PM
Hi Randy,
Thank you for your reply. I will try it later.
04-23-2012 03:46 PM
Hi Jean-Philippe,
I have not worked out this issue yet.
In my environment,
- two out of three L2-mode SG300-10 express the logs.
- two L3-mode SG300-10 have no problem.
- one L2-mode SF302-08P expresses the logs.
- one SG200-50 has no problem.
All of the above are running with firmware 1.1.2.0.
