SG300-20 - Problems with Forwarding and Learning MACs until Write
jeff-rogers
I have an SG300-20 and started having problems a few weeks ago.  Primarily the problem is related to rebooting systems, waking systems from sleep, or any other activity such as speed/duplex changes on the host that cause the host NIC to cycle.  Regardless of how the host NIC "goes down", when the host NIC "turns up" it shows connected on the host and switch, but the SG300 refuses to learn the MAC.  The only remedy seems to be the write command.  Immediately after the write command is issued there is delay from 0 to a few seconds, then L2 connectivity returns.
Also, a new problem cropped-up during testing after changing the mode to "route."  If I reload the switch it stops forwarding all traffic until a write command is issued.
Anyone see these symptoms and have a solution?
Jeff
26 Replies 26
Tom Watts
Hi Jeff, first, what software version do you use?
Seconds, have you looked at any of the Energy Efficient Ethernet settings? (You may want to disable them).
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom,
Thanks for your response.
I have tested both the previous release (1.3.0.36 I believe) as well as the most recent release 1.3.5.58.  Also, I have tried just about every EEE and Green-Ethernet setting possible, including disabling EEE and GreenEth.
Any other ideas?
Jeff
Hi Jeff, it may be spanning tree related or it could be software related.
Does the switch have any config on it in particular?
Globally disable spanning tree and see what happens.  Do you have a second switch around? May be test with a completely default switch and see if the behavior follows.
-Tom
Hi Tom,
Thanks for the suggestion.
I have tried disabling all of the following at one time or another:
-CDP
-LLDP
-Bonjour
-EEE
-Green-Ethernet
-SmartPort Global
-SmartPort on interface
I have also tried the following:
-STP Portfast
-Downgrading firmware
-Upgrading firmware
-Factory reset
-Hard setting speed and duplex (1000F, 100F, 100H)
-Autonegotiation (100F, 100F, 100H, slave, master)
-With Flowcontrol
-Without Flowcontrol
-MDIX on
-MDIX off
-Router mode
-Switch mode
-with NTP configured
-without NTP configured
-with Syslog configured
-without syslog configured
-with only a basic config after reset:  one vlan with the mgmnt address and one access port (and also with two access ports)
Any other ideas?
Jeff
Forgot to mention....
Also have tried disabling STP - no luck.
Hi Jeff,
sorry for my very late answer,
my problem is solved - i got a new sg300 from cisco and sold it on ebay....
Another symptom I saw again, but only once in past testing is that after a reload, all ports seem to bounce up and down continuously, even though the port lights do not show up/down status.  I have only seen this twice, and I get continuous logs to the console when it happens.  Again, none of the ports learn MACs and only a write command seems to correct it.
It sounds very similar to the following case:
https://supportforums.cisco.com/message/3959254#3959254
In my opinion this switch has a hardware problem.  How do I get it swapped under warranty?
Jeff
Hi Jeff, from the US 1.866.606.1866
Here's a list by country
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
-Tom
Hi Jeff,
is your case solved? I have still the same problem. After powering on the switch only a write mem command via the serial console brings it to work. I'm running the latest firmware and bootloader (FW 1.3.5.58) and made already factory reset. Were your problems hardware affected?
regards, Christian
Christian,
No solution yet.  And I'm stuck in Cisco's support hell....there bussines support is located in China (UTC+8) which means only one email exchange a day.  At this rate we'll be running IPv8 before it's fixed...
Will post if I get a fix.
Jeff
Hi Jeff,
thanks for your quick response. So we have to wait... Thanks so far!
Hi Jeff and Christian, can you give exact step to recreate? I'm having problems to recreate the problem.
Is this dependent on a certain network card or device?
Please provide the exact step by step how you can create this problem and if it is localized to any 1 type of connection or all connections.
-Tom
Hi Tom,
Steps to recreate my issue:
1.  Factory reset SG300-20
2.  Ping from Host A to Host B and/or vice versa
3.  Ping unsuccessful until “write” command issued
Notes:
- Upon issuing write command, connectivity is either immediate or up to a few seconds later
- Until a write command is issued, the “sh mac address-table” command shows no MACs except that of the switch itself on port 0
Also, I see these same symptoms for a host if the NIC on the host transitions (down/up).  Upon a transition the switch does not learn the MAC address and the “sh mac address-table” command shows no MAC for the host NIC that transitioned.
BTW - I appreciate your help and quick responses and I did open a TAC ticket.  However, it is frustrating that the TAC resource is UTC+8, only provides support during their work hours, and does not provide a local phone number.
Jeff
Jeff, I can't recreate this.
switch0d8210#set system mode switch
Changing the switch working mode will *delete* the startup configuration file
and reset the device right after that. It is highly recommended that you will
backup it before changing the mode, continue ? (Y/N)[N] Y
switch0d8210#10-Oct-2013 17:19:08 %FILE-I-DELETE: File Delete - file URL flash:/
/startup-config
switch0d8210#reload
You haven't saved your changes. Are you sure you want to continue ? (Y/N)[N] Res
etting local unit
*****************  SYSTEM
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................PASS
Flash Image Validation Test.......................PASS
BOOT Software Version 1.3.5.06 Built  21-Jul-2013  15:12:10
Networking device with Marvell ARM CPU core. 128 MByte SDRAM.
I-Cache 16 KB. D-Cache 16 KB. L2 Cache 256 KB. Cache Enabled.
MAC Address   :  00:26:0b:0d:82:10.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
Preparing to decompress...
100%
Decompressing SW from image-1
100%
OK
Running from RAM...
GPIO ID is 3
Module type is 10
Device ID 0xdff411ab
*** Running  SW  Ver. 1.3.5.58  Date  10-Oct-2013  Time  17:15:41 ***
HW version is V01
Base Mac address is: 00:26:0b:0d:82:10
Dram size is  : 128M bytes
Dram first block size is  : 102912K bytes
Dram first PTR is  : 0x1780000
Dram second block size is  : 4096K bytes
Dram second PTR is  : 0x7C00000
Flash size is: 16M
.....10-Oct-2013 17:15:44 %CDB-I-LOADCONFIG: Loading running configuration.
10-Oct-2013 17:15:44 %CDB-I-LOADCONFIG: Loading startup configuration.
Device configuration:
Slot 1 - SG300-28P
Device 0: GT_98DX3025 (AlleyCat)
-- Unit Standalone                --
Tapi Version: v1.9.6
Core Version: v1.9.6
10-Oct-2013 17:16:20 %INIT-I-InitCompleted: Initialization task is completed
Detected speed: 115200
10-Oct-2013 17:16:34 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration c
hange trap.
10-Oct-2013 17:16:34 %SNMP-I-CDBITEMSNUM: Number of running configuration items
loaded: 0
10-Oct-2013 17:16:34 %SNMP-I-CDBITEMSNUM: Number of startup configuration items
loaded: 0
The SSH Server is generating a default RSA key.
This may take a few minutes, depending on the key size.
10-Oct-2013 17:16:35 %Environment-I-FAN-STAT-CHNG: FAN# 1 status changed - opera
tional.
The SSH Server is generating a default DSA key.
10-Oct-2013 17:17:20 %SYSLOG-N-LOGGING:
The SSH Client is generating a default RSA key.
User Name:cisco
Password:
This may take a few minutes, depending on the key size.e default settings. Please change the passwor
The SSH Client is generating a default DSA key.
d for better protection
10-Oct-2013 17:18:16 %SSL-I-SSLCTASK: Starting autogeneration of self-signed cer
Aging time is 300 sec
switchb2
tificate - 1024 bitsitchb29140#wr mem
Generating RSA private key, 1024 bit long modulus Port       Type
10-Oct-2013 17:18:24 %SSL-I-SSLCTASK: Autogeneration of self-signed certificate
   1       e0:5f:b9:b2:91:40       0
was successfully completed
Generating RSA private key, 1024 bit long modulush mac address-tab
User Name:
press ENTER key to retry authentication
User Name:
User Name:cisco
Password:*****
Please change your password from the default settings. Please change the passwor
d for better protection of your network. Do you want to change the password (Y/N
)[Y] ?N
switch0d8210#show mac address-table
  Vlan        Mac Address         Port       Type
   1       00:26:0b:0d:82:10       0         self
   1       64:31:50:1c:50:d3      gi3      dynamic
   1       d0:67:e5:56:14:32      gi2      dynamic
switch0d8210#
-Tom
