02-05-2013 05:50 PM
I use this oid to gather mac address: .1.3.6.1.2.1.17.4.3.1.1
This has worked on all of our cisco switches (3560,SG300, etc...). When an SG300-20 was updated to 1.2.7.76 the oid no longer exist.
snmpwalk -c public -v 2c switch .1.3.6.1.2.1.17.4.3.1.1
iso.3.6.1.2.1.17.4.3.1.1 = No Such Instance currently exists at this OID
Does anyone know what caused this? Should I downgrade the switch back to 1.1.2.0?
Thanks.
02-07-2013 04:57 PM
Hi Nathan, what is the exact object name? The bridge-mib is pretty large. If you could please let me know, I'll check in to this a bit deeper.
-Tom
Please mark answered for helpful posts
02-07-2013 05:02 PM
I am not sure what you mean?
Here is an excerpt from: http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a00801c9199.shtml
.1.3.6.1.2.1.17.4.3.1.1 dot1dTpFdbAddress OBJECT-TYPE -- FROM BRIDGE-MIB -- TEXTUAL CONVENTION MacAddress SYNTAX OCTET STRING (6) MAX-ACCESS read-only STATUS Mandatory DESCRIPTION "A unicast MAC address for which the bridge has forwarding and/or filtering information." ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) dot1dBridge(17) dot1dTp(4) dot1dTpFdbTable(3) dot1dTpFdbEntry(1) 1 }
02-07-2013 05:06 PM
Here are all the dot1d object names on the SX300 1.2.7.76
dot1dBaseBridgeAddress
dot1dBaseNumPorts
dot1dBasePortTable
dot1dBaseType
dot1dDeviceCapabilities
dot1dPortGarpTable
dot1dPortPriorityTable
dot1dStaticTable
dot1dStpBridgeForwardDelay
dot1dStpBridgeHelloTime
dot1dStpBridgeMaxAge
dot1dStpDesignatedRoot
dot1dStpForwardDelay
dot1dStpHelloTime
dot1dStpHoldTime
dot1dStpMaxAge
dot1dStpPathCostDefault
dot1dStpPortTable
dot1dStpPriority
dot1dStpProtocolSpecification
dot1dStpRootCost
dot1dStpRootPort
dot1dStpTimeSinceTopologyChange
dot1dStpTopChanges
dot1dStpVersion
dot1dTpAgingTime
dot1dTpFdbTable
dot1dTpPortTable
dot1dTrafficClassTable
-Tom
02-07-2013 05:10 PM
Does that mean the dot1dTpFdbAddress is not there? Should I go back to 1.1.2.0?
02-07-2013 05:12 PM
Yes, if it was there or working previously and you require it, you can downgrade to the 1.1.2.0.
If you have a backup file from the 1.1.2.0, I'd recommend to reset the switch after the downgrade. The reason being the 1.2.7.76 changed the XML the switch uses and you will have some lingering effects of the 1.2.7.76 with the change if you don't reset the unit.
-Tom
02-08-2013 08:57 AM
OK. Thanks for your help.
02-11-2013 05:19 PM
Hi Nathan, just to follow up. I got my hands on a switch with 1.1.2.0 code and I pulled the OID's off the unit. It looks like all of the object names match up to what the 1.2.7.76 output has for the dot1d object names.
dot1dBaseNumPorts
dot1dBasePortTable
dot1dBaseType
dot1dPortGarpTable
dot1dStaticTable
dot1dStpHelloTime
dot1dStpHoldTime
dot1dStpMaxAge
dot1dStpPortTable
dot1dStpPriority
dot1dStpRootCost
dot1dStpRootPort
dot1dStpTopChanges
dot1dStpVersion
dot1dTpAgingTime
dot1dTpFdbTable
dot1dTpPortTable
dot1qFdbTable
dot1qForwardAllTable
-Tom
02-12-2013 08:40 AM
That's strange. Does that mean that technically it shouldn't work on the 1.1.2.0?
02-14-2013 04:52 PM
Hi Nathan, I have confirmed this in my lab. I have engaged Cisco. Here is my ticket number for tracking
624830577
-Tom
02-14-2013 04:55 PM
Wow! Thanks Tom.
10-02-2013 07:50 AM
Any updates on this? I have the same issue.
10-02-2013 08:26 AM
There's a beta firmware to address this problem. Should be out next release.
-Tom
10-02-2013 08:43 AM
Thanks for the quick reply!
