SG300-20 Update to 1.2.7.76 lost OID
natewlew1
I use this oid to gather mac address: .1.3.6.1.2.1.17.4.3.1.1
This has worked on all of our cisco switches (3560,SG300, etc...). When an SG300-20 was updated to 1.2.7.76 the oid no longer exist.
snmpwalk -c public -v 2c switch .1.3.6.1.2.1.17.4.3.1.1
iso.3.6.1.2.1.17.4.3.1.1 = No Such Instance currently exists at this OID
Does anyone know what caused this? Should I downgrade the switch back to 1.1.2.0?
Thanks.
13 Replies 13
Tom Watts
Hi Nathan, what is the exact object name? The bridge-mib is pretty large. If you could please let me know, I'll check in to this a bit deeper.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
I am not sure what you mean?
Here is an excerpt from: http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a00801c9199.shtml
dot1dTpFdbAddress OBJECT-TYPE
         -- FROM BRIDGE-MIB
         -- TEXTUAL CONVENTION MacAddress
         SYNTAX          OCTET STRING (6)
         MAX-ACCESS      read-only
         STATUS          Mandatory
         DESCRIPTION    "A unicast MAC address for which the bridge has forwarding
                 and/or filtering information."
::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) dot1dBridge(17) dot1dTp(4)
dot1dTpFdbTable(3) dot1dTpFdbEntry(1) 1 }
Here are all the dot1d object names on the SX300 1.2.7.76
      dot1dBaseBridgeAddress
      dot1dBaseNumPorts
      dot1dBasePortTable
      dot1dBaseType
      dot1dDeviceCapabilities
      dot1dPortGarpTable
      dot1dPortPriorityTable
      dot1dStaticTable
      dot1dStpBridgeForwardDelay
      dot1dStpBridgeHelloTime
      dot1dStpBridgeMaxAge
      dot1dStpDesignatedRoot
      dot1dStpForwardDelay
      dot1dStpHelloTime
      dot1dStpHoldTime
      dot1dStpMaxAge
      dot1dStpPathCostDefault
      dot1dStpPortTable
      dot1dStpPriority
      dot1dStpProtocolSpecification
      dot1dStpRootCost
      dot1dStpRootPort
      dot1dStpTimeSinceTopologyChange
      dot1dStpTopChanges
      dot1dStpVersion
      dot1dTpAgingTime
      dot1dTpFdbTable
      dot1dTpPortTable
      dot1dTrafficClassTable
-Tom
Does that mean the dot1dTpFdbAddress is not there? Should I go back to 1.1.2.0?
Yes, if it was there or working previously and you require it, you can downgrade to the 1.1.2.0.
If you have a backup file from the 1.1.2.0, I'd recommend to reset the switch after the downgrade. The reason being the 1.2.7.76 changed the XML the switch uses and you will have some lingering effects of the 1.2.7.76 with the change if you don't reset the unit.
-Tom
OK. Thanks for your help.
Hi Nathan, just to follow up. I got my hands on a switch with 1.1.2.0 code and I pulled the OID's off the unit. It looks like all of the object names match up to what the 1.2.7.76 output has for the dot1d object names.
      dot1dBaseNumPorts
      dot1dBasePortTable
      dot1dBaseType
      dot1dPortGarpTable
      dot1dStaticTable
      dot1dStpHelloTime
      dot1dStpHoldTime
      dot1dStpMaxAge
      dot1dStpPortTable
      dot1dStpPriority
      dot1dStpRootCost
      dot1dStpRootPort
      dot1dStpTopChanges
      dot1dStpVersion
      dot1dTpAgingTime
      dot1dTpFdbTable
      dot1dTpPortTable
      dot1qFdbTable
      dot1qForwardAllTable
-Tom
That's strange. Does that mean that technically it shouldn't work on the 1.1.2.0?
Hi Nathan, I have confirmed this in my lab. I have engaged Cisco. Here is my ticket number for tracking
624830577
-Tom
Wow! Thanks Tom.
Any updates on this?  I have the same issue.
There's a beta firmware to address this problem. Should be out next release.
-Tom
Thanks for the quick reply!
