12-29-2018 08:17 PM
Hi There,
I have an AP 3502i and a SG300-28p, but for some reason I can't configure this switch to open all vlans I have configured on my AP device. Actually, I have a native vlan (vlan 20) and 2 other vlans (30 and 32) configured on my AP, but I still can't put this 2 devices to talk each other regarding this 3 vlans.
Bellow you can see my AP configuration as well as my switch configuration. Any tip ?
AP Config
interface GigabitEthernet0.20
encapsulation dot1Q 20 native
bridge-group 1
bridge-group 1 spanning-disabled
no bridge-group 1 source-learning
interface GigabitEthernet0.30
encapsulation dot1Q 30
bridge-group 30
bridge-group 30 spanning-disabled
no bridge-group 30 source-learning
interface GigabitEthernet0.32
encapsulation dot1Q 32
bridge-group 32
bridge-group 32 spanning-disabled
no bridge-group 32 source-learning
interface BVI1
ip address 10.0.0.2 255.255.255.0 (it's a vlan 20 address)
Switch config
interface gigabitethernet24
switchport trunk allowed vlan add 30,32
switchport trunk native vlan 20
On my ASA 5505,where I still have this AP connected (for while), I have this commands to support all those vlans
ASA config
interface Ethernet0/7
switchport access vlan 20
switchport trunk allowed vlan 20,30,32
switchport mode trunk
12-30-2018 03:29 AM
Try change native VLAN to different VLAN(any thing other than 20 and allow vlan 20 in to allow list)
Switch config
switchport trunk allowed vlan add 20,30,32
switchport trunk native vlan 40 < --- example this vlan not part, so all black-hole vlan will be tageed)
01-01-2019 12:22 AM
Hello Gustavo,
Happy new 2019 year!
what gives you command? :
switchxxxxxx# show interfaces switchport gi24
01-13-2019 06:01 AM
Hi Mipopov,
Happy new year for you too !!!
Here's the output
Switch#sh interface switchport gi24
Port : gi24
Port Mode: Trunk
Gvrp Status: disabled
Ingress Filtering: true
Acceptable Frame Type: admitAll
Ingress UnTagged VLAN ( NATIVE ): 1
Port is member in:
Vlan Name Egress rule Port Membership Type
1 1 Untagged Static
20 inside Tagged Static
30 wifi Tagged Static
32 guest Tagged Static
Forbidden VLANS:
Vlan Name
Classification rules:
Switch#
And here's my port configuration
interface gigabitethernet23
storm-control broadcast enable
Description "Connected to Cisco AP"
Thank you
01-16-2019 04:45 AM
Hello Gustavo,
Try to make vlan 20 native to trunk :
Switch(config)# interface gi24 Switch(config-if)# switchport trunk native vlan 20
Hope it helps
Cheers,
Mike
