06-09-2016 05:41 AM
Hi All,
I am having a strange problem. I have a POE switch and an AP. They've both been working for a year now. Recently my switch POE function broke and I had to RMA the switch. In the meantime, I've moved the AP to a different POE switch. The switch powers up the AP via POE, but the port on the switch will not come up. There are other ports on this switch powering other AP's just fine.
SW168KualaLumpur300A#show run int gi16
interface gigabitethernet16
power inline priority critical
switchport trunk allowed vlan add 22
SW168KualaLumpur300A#show power inline
Port based power-limit mode
Unit Power Nominal Power Consumed Power Usage Threshold Traps Temp (C)
1 On 180 Watts 16 Watts (9%) 95 Disable 41
Port Powered Device State Status Priority Class
gi1 Auto Searching low class3
gi2 Auto Searching low class3
gi3 Auto Searching low class3
gi4 Auto Searching low class3
gi5 Auto Searching low class3
gi6 Auto Searching low class3
gi7 Auto Searching low class3
gi8 Auto Searching low class3
gi9 Auto Searching low class3
gi10 Auto Searching low class3
gi11 Auto Searching low class3
gi12 Auto Searching low class3
gi13 Auto Searching low class3
gi14 Auto Searching low class3
gi15 Auto Searching low class3
gi16 Auto On critical class3
gi17 Auto Searching low class3
gi18 Auto Searching low class3
gi19 Auto Searching low class3
gi20 Auto On low class3
gi21 Auto Searching low class3
gi22 Auto On low class3
gi23 Auto Searching low class3
gi24 Auto Searching low class3
SW168KualaLumpur300A#show int stat
Flow Link Back Mdix
Port Type Duplex Speed Neg ctrl State Pressure Mode
gi1 1G-Copper Full 1000 Enabled Off Up Disabled On
gi2 1G-Copper -- -- -- -- Down -- --
gi3 1G-Copper -- -- -- -- Down -- --
gi4 1G-Copper -- -- -- -- Down -- --
gi5 1G-Copper -- -- -- -- Down -- --
gi6 1G-Copper -- -- -- -- Down -- --
gi7 1G-Copper -- -- -- -- Down -- --
gi8 1G-Copper -- -- -- -- Down -- --
gi9 1G-Copper -- -- -- -- Down -- --
gi10 1G-Copper -- -- -- -- Down -- --
gi11 1G-Copper -- -- -- -- Down -- --
gi12 1G-Copper -- -- -- -- Down -- --
gi13 1G-Copper -- -- -- -- Down -- --
gi14 1G-Copper -- -- -- -- Down -- --
gi15 1G-Copper -- -- -- -- Down -- --
gi16 1G-Copper -- -- -- -- Down -- --
gi17 1G-Copper -- -- -- -- Down -- --
gi18 1G-Copper -- -- -- -- Down -- --
gi19 1G-Copper -- -- -- -- Down -- --
gi20 1G-Copper Full 1000 Enabled Off Up Disabled On
gi21 1G-Copper -- -- -- -- Down -- --
gi22 1G-Copper Full 1000 Enabled Off Up Disabled On
gi23 1G-Copper Full 1000 Enabled Off Up Disabled Off
gi24 1G-Copper -- -- -- -- Down -- --
gi25 1G-Copper -- -- -- -- Down -- --
gi26 1G-Copper -- -- -- -- Down -- --
gi27 1G-Combo-F Full 1000 Disabled Off Up Disabled Off
gi28 1G-Combo-C -- -- -- -- Down -- --
Ports 22 & 20 are powering other AP's without a problem.
I have swapped out the network cable, tried a shut/no shut on the port, tried assigning power inline priority critical on the switchport, tried reloading the switch, but no luck. I am starting to think the AP has broke but that would be a heck of a coincidence that two devices broke at the same time (the switch with the POE function that broke and the AP connected to it).
Has anyone seen this or does anyone have any theories? Cross-over cable perhaps needed for some reason?
06-10-2016 09:44 AM
Will the port come up with just a standard client connected?
06-15-2016 05:41 AM
Yes it will. I have actually tried it with straight and cross cables, on two switches and 1 ASA in the POE port now and the symptoms are the same on all devices; Green light on AP, powered up, link down, no light on POE port.
