SG300/500 L3 changing management VLAN IP?
viningele
Level 3
Level 3
Why is it such a pain to change the IP?  I know now that you have the set the management vlan IP as static before doing anything else but once that's done and you then add more vlans and with their own static IPs why can't I change the management IP to something else should I desire.
When I try and it hangs is that because the attempt forces the sw to change management vlans and then because I can't save the config cuz I'm not on that vlan, acually I'm working remotely and not physically connected, the change isn't saved and my remote power cycling of the sw just brings me back to square one. Just like when leaving the management set as DHCP and then adding a vlan with a static IP seemingly hangs the sw when in reality it just changes your management vlan.
Of course you can't change the IP if already static even if no other vlans are yet defined.  At least I couldn't, I'm sure there's some convoluted method that I couldn't grasp.
If that's the case do I need to be onsite and set up an access port for the next vlan in line that will presumably become to be the management vlan when I attempt the IP change.
6 Replies 6
Tom Watts
Hi Vini, in layer 3 mode, each VLAN interface is considered a management IP.
I'm glad you got past the static IP for VLAN 1 as that's the true caveat. If you log in to a fresh reset layer 3 switch
config t
int vlan 1
ip address 192.168.1.254 /24
this sets static from dynamic then you can create additional vlan interface
config t
vlan database
vlan 2-10
int vlan 2
ip address 192.168.2.254 /24
int vlan 3
ip address 192.168.3.254 /24
From here, if you desire to change vlan 1 it should be no issue, naturally you will loose connection until you reconnet to the new ip
config t
int vlan 1
ip address 192.168.1.200 /24
------> at this point you should lose connectivity until you reconnect at the 192.168.1.200.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Everytime I try that exact same procedure for vlan 1 I get.
Currently vlan 1 it's set to 192.168.175.148 and all my other vlan management ips are 192.168.x.10
conf t
Int vlan 1
ip address 192.168.175.10 /24
Duplicated IP interface on same subnet
If I then do
no ip address 192.168.175.10
ip address 192.168.175.10 does not exist on interface
Any idea why?
Hi Vini, can you post a show run of the switch at it's current state of when it produces the error?
-Tom
Here the Show Run, Show Vlans and Show IP Route
SW-SG300-28-1#show run
config-file-header
SW-SG300-28-1
v1.3.0.62 / R750_NIK_1_3_647_260
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 25,75,100
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
bonjour interface range vlan 1
hostname SW-SG300-28-1
line console
exec-timeout 30
exit
line ssh
exec-timeout 30
exit
line telnet
exec-timeout 30
exit
no passwords complexity enable
username xxxxxxxxaccc privilege 15
ip ssh server
snmp-server server
snmp-server location "xxxxxxx"
snmp-server contact "xxxxxxx"
ip http timeout-policy 1800
clock timezone " " -4
clock summer-time web recurring usa
clock source sntp
clock source browser
ip telnet server
interface vlan 1
ip address 192.168.175.148 255.255.255.0
no ip address dhcp
interface vlan 25
name "Guest Wi-Fi"
ip address 192.168.176.10 255.255.255.0
interface vlan 75
name Data
ip address 192.168.178.10 255.255.255.0
interface vlan 100
name POS
ip address 192.168.177.10 255.255.255.0
interface 1
switchport forbidden default-vlan
interface gigabitethernet1
description "ADMIN PVID1"
storm-control broadcast enable
storm-control broadcast level 10
storm-control include-multicast
port security max 10
port security mode max-addresses
port security discard trap 60
spanning-tree portfast
switchport mode access
switchport forbidden vlan add 25
macro description desktop
macro auto smartport type desktop $max_hosts 10 $native_vlan 1
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
interface gigabitethernet6
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet9
switchport access vlan 100
interface gigabitethernet10
interface gigabitethernet11
interface gigabitethernet12
interface gigabitethernet13
interface gigabitethernet14
interface gigabitethernet15
interface gigabitethernet16
interface gigabitethernet17
interface gigabitethernet18
interface gigabitethernet19
interface gigabitethernet20
interface gigabitethernet21
description "PAK AP Bar"
interface gigabitethernet22
description "PAK AP Dining"
interface gigabitethernet23
spanning-tree link-type point-to-point
switchport trunk allowed vlan add 25,75
macro description ap
macro auto smartport type ap
interface gigabitethernet24
interface gigabitethernet25
description Router
switchport trunk allowed vlan add 25,75,100
macro description router
macro auto smartport type router $native_vlan 1
interface gigabitethernet26
macro description switch
macro auto smartport type switch $native_vlan 1
interface gigabitethernet27
interface gigabitethernet28
exit
SW-SG300-28-1#
SW-SG300-28-1#show vlan
Vlan       Name                   Ports                Type     Authorization
1           1             gi1-8,gi23-28,Po1-8       Default      Required
25     Guest Wi-Fi              gi23-28              static      Required
75        Data                  gi23-28              static      Required
100         POS              gi9-22,gi25-28           static      Required
SW-SG300-28-1#show ip route
Maximum Parallel Paths: 1 (1 after reset)
IP Forwarding: enabled
Codes: > - best, C - connected, S - static
C   192.168.175.0/24 is directly connected, vlan 1
C   192.168.176.0/24 is directly connected, vlan 25
C   192.168.177.0/24 is directly connected, vlan 100
C   192.168.178.0/24 is directly connected, vlan 75
Additional info:
I'm connecting to an RV320 on its port 1 from port 25 on the SG300 and the RV320 is providing the DHCP servers using 192.168.x.1.  Port 1 on the RV320 is 1U, 25T, 75T, 100T.  My PPTP VPN range has been shifted to 192.168.175.221-229.  My lowest DHCP range is 20 and I don't think there's anything else reserved on the router so .10 should be clear there.
I was watching a vid on SVI and I think I may have found an issue, possibly the issue.
Video: http://m.youtube.com/watch?v=Wl_-tdnCUEE
Apparently using int vlan x doesn't create the vlan but a layer 3 logical interface for the vlan and I think my config created a layer 3 logical interface on the switch on .148 and on the RV320 on .1 for vlan 1 and .10 and .1 for the other vlans.  I think this might be bad but I'm not sure yet.
Presently I'm routing on the RV so I'm guessing I shouldn't be assigning IPs to the vlans on my switch since I'm basically using the router on a stick setup.  If I change my setup and route on the switch and I would then need to setup my vlan logical interfaces on the switch, probably run my dhcp servers, pools and binding on the switch and then set up the RV on a completely different subnet from any of my vlans just to act as the gateway.
I'll have to watch the video a few more times and see if I can actually grasp the concepts and then find a few more videos to help connect the missing dots.
