12-22-2015 04:45 AM
Hello all,
We have two SG300-52P switches, one of them in L3 mode (sw-01) and the second one is for the IP phones with PoE (sw-02)
The logs on the switch sw-01 reporting CDB overflow:
STCDBOVERFLOW - %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262070, file end = 262080, aggregated (10)
CDB - CDBOVERFLOW - %CDB-W-CDBOVERFLOW: Overflow in CDB, aggregated (10)
Both switches are running the latest firmware 1.4.1.3 and the boot version 1.3.5.06
The sw-01 also configured as root bridge with the priority 24576 and the ports GE1-GE48 with the portfast.
Also, there are few VLANS configured and there are packet drops when pinging those gateways. However, no packet drops when pinging between hosts.
Could anyone advice the cause of the problem and how to fix it.
Thank you in advance,
Zak
01-29-2016 07:11 AM
Thanks to Cisco support for helping to fix this issue.
05-03-2023 01:00 AM
Hi! Having exaclty the same problem. How did Cisco support fix this issue?
