SG300 DHCP DNS Server Configuration
patrick.hurley
Level 3
Level 3
I am trying to figure out via command line how to add multiple DNS servers to an SG300.    The GUI only allows one DNS server.   I cannot find any command line documentation for the SG300's.    Anyone have a link to the command line documentation?
marce1000
  - Following this document you should be able to use the Add button in the DNS server menu in order to add DNS servers, I could also verify this by using : http://www.cisco.com/assets/sol/sb/SG300_Emulators/SG300_Emulator_v1-2-9/config/home_SG_300-52_1_2_9.htm
 M.
patrick.hurley
Level 3
Level 3
Here is what I am talking about on the DHCP configuration.  It only allows one DNS entry on the DHCP configuration page.2022-11-17_09-28-27.jpg
 - That's about using the device as a DHCP server (defining a pool) , this seems to be a limitation (only one dhcp server can be specified), consider using external appliance(s) for dhcp services.
 M.
KJK99
Level 3
Level 3
@patrick.hurley
Google 'sg300 cli guide'
Kris K
