SG300 - Error No More IP addresses could be added
dmackerracher
I'm trying to add an additional vlan on to an SG300. I've created the vlan, but when I try and assign the vlan interface a static IP, I get an error message 'No more IP addresses could be added'.
I get that error from both CLI and GUI. Currently, there are only 2 other vlan's, and I have a test SG300 that has more vlan's and IP addresses for interfaces assigned.
Any idea what's going on?
Here's the relevant section from the config:
interface vlan 1
 ip address 192.168.1.32 255.255.255.0
 no ip address dhcp
interface vlan 10
 name Main
 ip address 192.168.42.254 255.255.255.0
 ip dhcp relay enable
interface vlan 20
 name "Building 3"
 ip address 192.168.45.254 255.255.255.0
interface vlan 30
 name "Building 2"
It's vlan 30 I can't add the IP address to.
Cheers,
Donald.
15 Replies 15
Aleksandra Dargiel
Hi Donald,
There is no reason you should get this error. And I have not seen such an error before. It would be interesting to see full configuration file together with with the configuration steps taken and error message.
Aleksandra
Configuration isn't particularly complex. Here it is with suitable bits removed.
sh running-config
config-file-header
xxxxxx
v1.3.7.18 / R750_NIK_1_35_647_358
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 10,20,30
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp snooping
no ip dhcp snooping verify
ip dhcp snooping information option allowed-untrusted
arp timeout 300
ip dhcp relay address 192.168.42.6
ip dhcp information option
bonjour interface range vlan 1
hostname xxxxxxx
username xxxxxx password encrypted xxxxxxxxx privilege 15
clock timezone " " 0 minutes 0
clock source sntp
no ip domain lookup
ip domain timeout 2
ip domain retry 1
interface vlan 1
 no ip address dhcp
interface vlan 10
 name Main
interface vlan 20
 name "Building 3"
interface vlan 30
 name "Building 2"
interface gigabitethernet1
 switchport trunk native vlan 10
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
interface gigabitethernet6
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet9
interface gigabitethernet10
interface gigabitethernet11
interface gigabitethernet12
interface gigabitethernet13
interface gigabitethernet14
interface gigabitethernet15
interface gigabitethernet16
 switchport trunk native vlan 20
interface gigabitethernet17
interface gigabitethernet18
interface gigabitethernet19
interface gigabitethernet20
interface gigabitethernet21
interface gigabitethernet22
 switchport mode access
 switchport access vlan 20
interface gigabitethernet23
interface gigabitethernet24
interface gigabitethernet25
interface gigabitethernet26
interface gigabitethernet27
 switchport trunk native vlan 30
interface gigabitethernet28
exit
ip default-gateway 192.168.42.11
And the error:
switchxxxxxx#conf
switchxxxxxx(config)#interface vlan 30
switchxxxxxx(config-if)#ip address 192.168.46.254 255.255.255.0
No more IP addresses could be added.
Cheers,
Donald.
Hi Daniel,
I added your configuration and even so managed successfully add IP address for VLAN 30, the same as yours.
But please note:
switchef113d(config)#do sh version
SW version    1.4.0.88 ( date  06-Aug-2014 time  16:55:55 )
Boot version    1.3.5.06 ( date  21-Jul-2013 time  15:12:10 )
HW version    V01
Aleksandra
Hi Aleksandra,
Here's what I get.
do sh version
SW version    1.3.7.18 ( date  12-Jan-2014 time  18:02:59 )
Boot version    1.1.0.6 ( date  11-May-2011 time  18:31:00 )
HW version    V02
I see the same as you. On another switch, the config is fine and I can add an address. Typically, the one it is failing on is in a production environment. I will try a switch reboot out of business hours and see what happens. Failing that, I'll then do a firmware upgrade I guess.
Cheers,
Donald.
Hi Donald,
You definitely need to do boot code upgrade. Since version 1.3.5 boot code also was changed and those two should match as there pretty fundamental changes in file system. Reboot it is not good enough :-)
Aleksandra
I am facing the same error, unfortunately I already upgraded both boot code and firmware prior to install and configure the switch.
On the other side I have a backup switch, I am going to make some tests on it.
I will try to reboot the main switch ASAP and make you know, however it's a weird situation, now I am in trouble with my customer.
Hi Matteo,
If this is urgent case I would recommend you to open ticket with Small Business Support team:
http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
so they can get more detailed information and investigate further.
Aleksandra
I was able to change the configuration on the backup switch, so I downloaded the new configuration and uploaded it on the main switch, now I am waiting for the customer to reboot it during holidays.
Is there any limitation on the number of  IP address?
I was trying to add IP address to each VLAN.
When I added around 50 IP addresses, it shows "No more IP addresses could be added."
switch4219a2(config)#interface vlan 748
switch4219a2(config-if)#ip address 172.18.1.193 /30
Please see the attachment for detail.
PS. The switch I'm using is SG300-28 28-Port Gigabit Managed Switch.
Facing just the same problem here. Also in a simple scenario.
COREVS#sh ver
HW version    V02
The only thing that dmackerracher and I have in common is the HW Version (v02), while your, Aleksandra Dargiel , is a V01.
Just upgraded the SW/Boot this weekend so I could bring up those ip addresses, but it seems to be a bug. I don't know. Unfortunately, I don't have a valid SMB support contract to open a ticket :(
Dear Aleksandra,
I having same issue like this, please advise below version details;
switch7796d6#sh ver
HW version V02
switch7796d6#
May I know is there any possibility current configuration on the switch will be erase after applying the update?
Thank you.
Saad
pdarce001
Hi dmackerracher,   can u solve the problem??...  i have the same dificult...!!!
FW   1.3.5.58
boot   1.1.0.6
appreciate your help...  tnx..
Pablo
Hi Pablo,
Please try to upgrade boot code as well which for 300 series should be sx300_boot-13506.rfb and reboot the switch.
Aleksandra
DCC4405ITM
I had this problem too but found a workaround. You need to reboot the switch after making changes to the VLAN settings, then you can add the IP interface without the address error.
Upgrading the firmware only works once as it causes a reboot. You have to reboot after every VLAN change.
Cheers,
Brett.
