SG300 firmware 1.3.0.59 Bug
vashkenazy
Hi all, I'm having troubles with this firmware in a SG300-28 switch. Actually the DHCP server, a new feature in this firmware release, doesn't work correctly. DHCP static reservations are not working: CLient ID and MAC address are not recognized correctly, and the DHCP server assigns the first free IP in the pool, rather than the reserved one.
If Cisco engineers read this, plese correct the issue.
The issue is well documented in this thread, and it's present in series 500 too:
https://supportforums.cisco.com/message/3941468#3941468
Any help is appreciated.
Thanks, Andrea
Hi Andrea, the command is available on the global config
configure terminal
ip dhcp server
If the command is not available it is because you're not using at least 1.3.0.59. I am running 1.3.0.59 and 1.3.0.62 and both software images have the command available.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
5 Replies 5
Tom Watts
Hi Andrea, I've found the same behavior.
-Tom
Hi Andrea,
I have this working with this config. My computer in use is a Window Vista HP laptop.
ip dhcp pool host Test
address 192.168.2.15 255.255.255.0 client-identifier 01:00:23:8b:44:5a:ed
default-router 192.168.2.1
switchce82d3#show run
config-file-header
switchce82d3
v1.3.0.59 / R750_NIK_1_3_647_260
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 2
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp server
exit
bonjour interface range vlan 1
hostname switchce82d3
interface vlan 1
ip address 192.168.100.129 255.255.255.0
no ip address dhcp
interface vlan 2
ip address 192.168.2.1 255.255.255.0
interface fastethernet3
switchport mode access
switchport access vlan 2
ip dhcp server
exit
interface vlan 1
no ip address dhcp
interface vlan 2
-Tom
Hi Tom, actually I upgraded firmware to 1.3.0.62 (1.3.0.59 is no longer available), but I still have the same problem.
I tried to configure DHCP server as you suggested, but via CLI no "ip dhcp server" command is available. The only command available seems to be "ip dhcp snooping". So the only option is to manage DHCP server via web interface.
Any suggestion?
Andrea
configure terminal
ip dhcp server
-Tom
Hi Tom, I managed to work DHCP configuration using your suggestions. Actually my problem was trying to reserve a static IP using a particular subnet mask: 255.255.254.0. That because this client should see, in my mind, both subnets allocated on the switch: 192.168.128.0 and 192.168.129.0.
But in this way the static assignment failed. Now, setting the 255.255.255.0 subnet to the host reservation works correctly, even if must use client-id (01+Mac). Using reservation via Mac address doesn't work.
BTW thank you a lot.
Andrea
