SG300 intervlan routing - ACL help
rdrisaldi
I setup switch SG300-52P in layer 3 mode.
I have 3 vlans (10,20,30) and ports assigned to every vlan.
Each host can ping its own gateway (depending the vlan).
I want to permit some traffic from a vlan to an specific host (server) on another vlan. I try with ACL but can't do it.
Can anybody help me how to do this?
thanks a lot.
Hi Ruy,
My ACL isa very restrictive.
ip access-list extended Restrict_FTP
permit ip 192.168.10.0 0.0.0.255 192.168.20.10 0.0.0.0
exit
It only permits the 192.168.10.0 network to get to the host 192.168.20.10  IP Host.
Maybe there should also be (in red) ;
deny ip 192.168.10.0  0.0.0.255  192.168.20.0  0.0.0.255
permit any any
exit
I have to admit i prefer using the GUI to produce my ACE entries.  The table it creates shows how the ACL is going to work. and importantly in what order.
  • The switch goes through the ACE entries in order from top to bottom as seen in the GUI.
  • The ACL that is attached to a interface,  pattern matching incoming packets (coming into the switch).
  • ACE entries use inverse masking which can be confusing.  Maybe the following tehnote may be useful for understanding the inverse masking;
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00800a5b9a.shtml
regards dave
10 Replies 10
David Hornstein
Level 7
Level 7
Hi Ray,
There is alot of stuff here on the community on ACL and 300 series.
It may be interesting to use the search option , but here is a link that may help you;
https://supportforums.cisco.com/thread/2136493?tstart=0
regards dave
Dave, thanks for your reply. I read your post
and I have a couple of question.
In your example you restricted a host to an FTP server. What if you want to allowed entire vlan 10 to a single host in vlan 20.
How would you do it ? and in which interface do you have to bind that ACL?
Thanks a lot.
Ruy
Hi Ruy
assume the VLAN10 network is 192.168.10.x
assume that the host in VLAN 20 is 192.168.20.10
exit
There is a impicit butnot seen command to deny all traffic at the end of the filter list above.
Since the switch  filters packets in ingress into the switch, I would apply the ACL to switch ports where i would see packets from 192.168.10.x network traffic coming into the switch.
interface gigabitethernet8
service-acl input Restrict_FTP
exit
David, thanks a lot gor your help. I´m going to try it.
In your example, if I have 30 ports on vlan 10 192.168.10.x I should apply this filter port by port?
Is there a cli command to apply the filter to whole vlan?
In the other example (restricted FTP) from your first link. what does it mean the 20-21 at the end?
deny tcp 192.168.10.106 0.0.0.0 any 192.168.10.101 0.0.0.0 20-21
thank you very much!
Ruy
David forget my last question (20-21) i didnt think about it. 20-21 are the ftp ports. Sorry about that.
I tried the acl you write in red and it doesnt work. I have no comunication between vlan 10 and that host. I think there is something wrong with some other part of configuration.
Hi Ruy,
exit
permit any any
exit
regards dave
bcoverstone
I have found the Cisco SBS switches do not utilize wildcard masking properly.  For example, I have the following access list.   I highlighted one of the configuration lines:
SW1#show access-list TEST
Extended IP access list TEST
    permit  ip any 192.168.12.0 0.0.0.255 ace-priority 40
    deny    ip any 192.168.13.0 0.0.0.255 ace-priority 60
    deny    ip any 192.168.50.0 0.0.1.255 ace-priority 80
    permit  tcp any any any 443 ace-priority 100
    permit  tcp any any any www ace-priority 120
    deny    tcp any any 192.168.0.0 0.0.255.255 22-23 ace-priority 140
    deny    tcp any any 192.168.0.0 0.0.255.255 69 ace-priority 160
    deny    tcp any any 192.168.0.0 0.0.255.255 1433 ace-priority 180
    deny    tcp any any 192.168.0.0 0.0.255.255 3306 ace-priority 200
    permit  tcp any any 192.168.0.0 0.0.255.255 3389 ace-priority 220
    deny    udp any any 192.168.0.0 0.0.255.255 161-162 ace-priority 240
    deny    udp any any 192.168.0.0 0.0.255.255 1812-1813 ace-priority 260
    permit  ip any host 192.168.1.88 ace-priority 280
    deny    ip any 192.168.0.0 0.0.3.255 ace-priority 300
    permit  ip any any ace-priority 320
This line seems to allow access to port 81 at 192.168.0.11 but deny the port on 192.168.0.12.
Unless I'm missing something, there is a serious security issue with the SG line of switches.
well this will need to be investigated closer so please go ahead and open case with Small Business Support team so they can diagnose.
I worked with the support team and it is a confirmed bug.
The id is  CSCvj91570
for those with access, you can look it up and follow it here
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvj91570
You rock!
My workaround was replacing our SG300's with a bunch of used C3560-X switches, that ended up costing about half as much as the SG300's did new...
