SG300 VLAN routing
nicholasp1
Hi There, I have a SG300-10MP, running in L3 Mode. connected to a ddwrt modem/router (to be replaced in the near future) 192.168.32.1
latest firmware, & 3x Networks
I am having issues routing between the VLANs and connecting to the Internet (or even the Router)
I am using both CLI and GUI and have been trying for a couple of days and feel as though I am constantly missing something simple.
What I want is to be able to access the Web from either VLAN and to be able to connect between the VLANs if required. I want to have as much of the setup on the SG300, so I can change the modem out with other models quickly.
I am running the SG300 as a DHCP server,
VLAN 20 is for PRI users (ports 1-4)
VLAN 30 is for SEC users (ports 5-8)
VLAN 40 is for the connection to the router. (port 10)
I can ping hosts on all 3 networks directly from the SG300, and I can Ping the SG300 interface address from other devices, (even across VLAN) but no device to device) (no firewalls etc as proven by the router to device ping)
I have tried ARP proxy ON and OFF with no change
any suggestions are appreciated.
Thank you in advance,
TESTSWITCH#show run
config-file-header
TESTSWITCH
v1.3.7.18 / R750_NIK_1_35_647_358
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 20,30,40
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp server
ip dhcp pool network PRI
address low 192.168.20.2 high 192.168.20.249 255.255.255.0
lease 5
domain-name PRI
dns-server 8.8.8.8
exit
ip dhcp pool network SEC
address low 192.168.30.2 high 192.168.30.249 255.255.255.0
dns-server 8.8.8.8
exit
bonjour interface range vlan 1
hostname TESTSWITCH
snmp-server location KEL
snmp-server contact NIC
interface vlan 1
 no ip address dhcp
interface vlan 20
 name PRI
 ip address 192.168.20.250 255.255.255.0
interface vlan 30
 name SEC
 ip address 192.168.30.1 255.255.255.0
interface vlan 40
 name TRUNK
 ip address 192.168.32.250 255.255.255.0
interface gigabitethernet1
 switchport mode access
 switchport access vlan 20
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
 switchport access vlan 30
interface gigabitethernet6
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet9
 ip address 192.168.2.250 255.255.255.0
interface gigabitethernet10
 switchport trunk native vlan 40
exit
banner login ^C
TEST
^C
banner exec ^C
BE CAREFUL
^C
ip default-gateway 192.168.32.1
Tom Watts
Hi Nicholas, this should help you
https://supportforums.cisco.com/discussion/12116176/rv042-082-016-sx300500-switch-open-discussion
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom, Thanks for the reply, I looked through the link provided and checked it against the config I used, The RV--- Router looks like a good option for further down the track, but with the ddwrt  at the moment I dont have the ability to allow multiple subnets, I have static routes on there already. Still no success.
