SG350-28P 28-Port Gigabit PoE Managed Switch
eempian
i have this switch and i have ubiquiti Access point ( unify ac lite ) see attached photo
this AP wirks using POe ports. i cant power any AP. i read that class and limitaions found and i know my access works on 6.5 wt but i do no know how to change to class 2- or let switch power my AP
AlKor
Check the cable. Possible it is damaged.
Switch autodetect class. Class 0 is enough for work.
Sujoy Paria
By default PoE ‘Power Mode’ is Class Limit in SG350 Switch. You may disable the PoE class error detection on the switch once and check. With this setting, if a class error is detected on an interface, it will be ignored and PD will be classified as class 0.
To disable PoE class error detection, use the power inline class-error-detection Global Configuration mode command. To return to default setting, use the no form of this command.
Syntax
power inline class-error-detection [enable|disable]
no power inline class-error-detection
Example:
switchxxxxxx(config)# power inline class-error-detection disable
Note: Please make sure the SG350 switch firmware is latest (2.5.0.83).
https://software.cisco.com/download/home/286288281/type/282463181/release/2.5.0.83?i=!pp
