SG350: Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x09, component CPLD
jane1
I'm, running a SG350XG-24F with software Version 2.4.0.94 and got lots of the following log messages:
26-Oct-2018 04:44:00 :%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x09, component CPLD
26-Oct-2018 04:41:42 :%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x0c, component CPLD
26-Oct-2018 04:38:13 :%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x07, component CPLD
26-Oct-2018 04:38:13 :%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x0d, component CPLD
26-Oct-2018 04:38:12 :%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x07, component CPLD
26-Oct-2018 04:38:12 :%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x0d, component CPLD
26-Oct-2018 04:35:47 :%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x0a, component CPLD
26-Oct-2018 04:33:23 :%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x09, component CPLD
26-Oct-2018 04:33:23 :%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x0e, component CPLD
26-Oct-2018 01:05:10 :%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x0d, component CPLD
26-Oct-2018 00:59:45 :%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x07, component CPLD
26-Oct-2018 00:52:40 :%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x0d, component CPLD
26-Oct-2018 00:47:27 :%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x0e, component CPLD
26-Oct-2018 00:44:39 :%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x09, component CPLD
26-Oct-2018 00:40:57 :%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x0c, component CPLD
26-Oct-2018 00:40:57 :%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x0f, component CPLD
26-Oct-2018 00:40:57 :%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x0b, component CPLD
Any ideas? Thank you!
jherrick
You ever figure this out? My sg550xg-8f8t on FW 2.4.5.71 gives this same error.  Changing out units did not solve the problem. Rebooting the switch fixes the problem for about 48-72 hours, than it reappears.
djtech2k
I am having the same error/issue with brand new CBS350 switches.  It seems to happen when we plug in our Cisco Copper SFP's (SFP-10G-T-X), but does not happen when we plug in the Cisco Fiber SFP's.
So far we have found no solution or statement from Cisco.
the problem reported on OP was different than yours,
what firmware version running, have you checked the compatible matrix does the device support SFP-10G-T-X) ?
https://tmgmatrix.cisco.com/?tpid=81
BB
