Stacking on CBS350-48T-4X
llima
Hi everyone,
I have two CBS350-48T-4X and I would like to stack them, my question is it possible using the Lan RJ-45 ports to configure the stack?
When I'm doing the Stack configuration, it only allows me to select the 4x SFP ports.
Is there an additional configuration I have to do so the other 48 Lan ports are available.. do I need to upgrade it, or if it's not supported indeed.
Thank you.
M02@rt37
Hello @llima
As concerned your platform, high-speed stack interconnects need SFP+ ports, so 10Gig fiber interfaces mandatory.
The uplink network ports will be configured for stacking and the proper interconnecting small form-factor pluggable (SFP) cables support the stack channel
https://www.cisco.com/c/en/us/support/docs/smb/switches/Cisco-Business-Switching/kmgmt2836-Stacking-Guidelines-for-CBS.html
Best regards
M02@rt37
Hello @llima
Best regards
Thank you, that solves my question.
