SG350 configuration problems
tommls
Trying to configure newly purchased sg350 switches.
1) how do I configure all the ports to be in trunk mode via the CLI?? -- 28 ports one at a time is not the ideal solution
2) have the most current firmware version 2.3.5.63 and the timeout set to never but often when I want to go to a different section of the UI, I must log in again, how to fix this??
3) when I create new VLANs they are all disabled, why??
4) why can I not activate Telephony OUI?? -- this switch will have IP phones attached to it and all our other Cisco switches have Telephone OUI turned on...
Thank you, Tom
cbfs
If you're comfortable using the CLI, you can configure ranges of interfaces there.
Ex.
config
inter range gi1-24
switchport mode trunk
exit
exit
The VLANs will probably show disabled until you connect a device to an interface using that VLAN.
tommls
I should say that I am still working with this sg350 with the default 192.x.x.x IP address, it still keeps logging me out when I change screens etc.
I also can not set the PVID of one of the ports, I need to have this switch configured the same as the sg300 that it is replacing.
I did finally get Telephony OUI enabled though.
Thank you, Tom
cbfs
Ex.
config
inter range gi1-24
exit
exit
