SG350X DAC Not Showing Up in UI
Snows
Could not find any info about DACs compatibility with the Sg350x28P line. From my understand they are just copper sfp+ passive or active. I really hope I did not buy a switch witch will not work for me. I have tried 2 different cables no difference in out come. Hope fully some with more Knowledge on this subject could school me Thanks.
mipopov
Yes, it should work if the switch sees it - these numbers mean the length of the cable in meters.
Cisco SFP-H10GB-CU1M
Twinax cable, passive, 30AWG cable assembly
1m
Cisco SFP-H10GB-CU1-5M
1.5m
Cisco SFP-H10GB-CU2M
2m
Cisco SFP-H10GB-CU2-5M
2.5m
Cisco SFP-H10GB-CU3M
3m
Cisco SFP-H10GB-CU4M
Twinax cable, passive, 24AWG or 26AWG cable assembly
4m
Cisco SFP-H10GB-CU5M
5m
As for the Mellanox - generally it should work as it is passive and not so long, but you can ask them, or consult with datasheet just in case.
Cheers,
Mike
mipopov
Happy New 2019 Year!
DAC cables:
SFP-H10GB-CU1M
SFP-H10GB-CU3M
SFP-H10GB-CU5M
Upgrade the firmware to latest :
https://software.cisco.com/download/home/286288281/type/282463181/release/2.4.5.71?i=!pp
The command to view the sfp:
switchxxxxxx# show inventory
Hope it helps
Cheers,
Mike
Will the SFP-H10GB-CU2M Not Work ? It does show up in Optical Module Status As a CU2M What is the difference ?
 Also I am Trying to Connect this to a Mellanox ConnectX-2 will these cable also work for that ?
mipopov
1m
1.5m
2m
2.5m
3m
4m
5m
Cheers,
Mike
