privilege level
tamas.horvath
Hi All,
How can a privelege level which give you the permission to execute only 'show running-config ' command be set on SG series switches?
Thank you in advance,
Tamas
7 Replies 7
mipopov
Hello Tamas,
Happy New 2019 Year!
Download the CLI guide for the Sx300 switches:
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/CLI_300.pdf
page 24 - User (Privilege) Levels
Hope it helps.
Cheers,
Mike
Is it somehow possible to define your own privilege level different from 1,7 or 15?
Not for these device i am aware of.
BB
Could it be realized with a tacacs/radius server neither?
yes i support other post you can use radius/tacacs/acs -  can do this job for you, since this SMB and only 1 router not make any sense for business case to have Radius server.
but options available many if you can able to install another component for this task.
BB
