SG350X - Port 25568 Issue or other problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-29-2018 06:37 AM
Purchased 2 SG350X to replace two older and out of port switches.
We use a Datto BDR device. Since changing out the switches this device cannot communicate, via port 25568 (see copy of Datto error message below).
My question: when I changed the default switch IP address (which was 192.168.1.254 to 192.168.1.245 (in our static range)) I had to create a new vlan with a bogus network setting a port to that vlan, change the ip of the desktop, then change the default IP address. Did this corrupt some setting so that it cannot communicate from Datto device to server? Note that 192.168.1.50 is the server. I can ping and tracert with no issue.
Thanks, Darryl
***** error message from device ****
XYZSERVER 192.168.1.50
× GET MORE INFO Backup Error at 1:31pm Wednesday November 28th
Critical backup failure: ABA1010 CURL Error: https://192.168.1.50:25568/backup: Failed to connect to 192.168.1.50 port 25568: No route to host
- Labels:
Small Business Switches
