SG350XG-24F hangs at "Loading system/images/active-image" on boot.
martinco-cae
I have a SG350XG-24F that will not boot properly. It gets to Loading system/images/active-image and hangs.
I have tried to XMODEM the firmware to it, but the transfer fails after a second.
I tried several versions of the firmware:
image_tesla_2.0.0.73.bin
image_tesla_hybrid_2.3.5.63.bin
image_tesla_hybrid_2.5.0.92_release_cisco_signed.bin
Any suggestions? Am I using the right firmware here?
Martin
Deepak Kumar
Upgrading boards running version 2.2.0.x to version 2.2.5.x is not possible via XMODEX due to Cisco Bug ID CSCva97605. Workaround:Use TFTP for upgrading from version 2.2.0.x to version 2.2.5.x.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hello Deepak,
I am unable to TFTP as the unit will not boot fully. The only option I am given is XMODEM.
What firmware version/file can be transferred with XMODEM?
Martin
Please share complete boot logs. I hope we will help you more.
Deepak Kumar,
Hello Deepak,
Thank you again. Unfortunately there are no logs I can access, as the switch does not boot up far enough. The first screen shot I posted is the first 3 seconds after power up.
The only option I am offered is to press 'x' to XMODEM and this I cannot get to work. I do not know if this is because I have the wrong firmware file or if the flash is corrupted/dead.
Are you aware of any undocumented key press options at the BootROM stage?
BootROM 1.20
Booting from NAND flash
DDR3 Training Sequence - Ver 5.3.DDR3 Training Sequence - Run with PBS.
BootROM: Image checksum verification PASSED
ROS Booton: Mar 16 2016 17:41:18
Press x to choose XMODEM...
Running UBOOT...
U-Boot 2013.01 (Dec 21 2016 - 22:00:47) Marvell version: 2014_T3.0_eng_dropv6 2.2.52
Loading system/images/active-image ... <-- This is where it hangs
If you have a technical service manual or similar that you could share, that would be great. A system board schematic would be useful too.
Cheers
Martin
