07-30-2017 08:05 AM
SG350XG-2F10-K9-EU - 10 x 10GE copper + 2 x 10GE SFP+
We have two HBA with SFP+ DAC (Mellanox ConnectX-3) we would like to connect to SG350XG, at the same time of other RJ45 10GE ports.
Are the SG350XG's two SFP+ stack ports usable as standard 10GE network port if you don't need stack?
Any limitation ?
Thank You.
Ben
07-31-2017 02:08 AM
I dont personally use these switches but you should be able to use them as per the admin doc
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/350xg/quick_start/guide/en-US/350XG-QSG-en-US.pdf
Stacking the Cisco 350XG Switches
Before configuring the switches as a stack, refer to the Cisco 350XG
Series 10G Stackable Managed Switches Administration Guide for
additional details. Refer to the front panel graphics in Cisco 350XG
Switches Features to help with the stack port descriptions and supported
modules.
By default the ports on a switch function as regular Ethernet ports except if
you configure them to do stacking. You cannot mix the stack speeds
between the switches or ports.
07-31-2017 07:47 AM
Thank You Mark.
Ben
01-08-2018 06:32 PM
Does the stacking cable comes with the box? or you need to buy it separately?
