sg500- Link Aggregation Control Protocol
Mk11
hi, I have a few questions about lacp. The documentation says that the ports that make up the etcherchannel must have the same speed and the same configurations on two switches (for example, they must be access port ).
On the switch A I changed the default speed port gi1/1/5 to 100 and I created a LAG on port gi1/1/5 and gi1/1/6, with auto mode option. On switch B I created LAB on port gi1/1/5 and gi1/1/6 without changing port configuration.  The link between the switches was created. I see that po1 port is up on both switches
Questions:
1)why a link between the switchs works in spite of the different configurations of ports on switch A and B ?
2) why the show interfaces status on switch A shows the speed of the port gi1/1/5 and po1 set to 1000 while the show interfeces configuration gi1/1/5 shows speed 100 ?
3) on switch A I set up por po1 to access mode
     a) why link works between switches ?
     b)  whether lacp should not automatically change port po1 on switch B in access mode ?
Iliya Gatsev
My name is Iliya Gatsev from Cisco Technical Support Team.
It will be good to call our support line and open a support case.
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Iliya Gatsev
Cisco STAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
