Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2865 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4416 Views
  • 1 replies
  • 16 Helpful votes
Hi , Can you provide me firmware for (SG300-28P 28-Port Gigabit PoE Managed Switch ). because when i upload any firmware (.ros) i get error message "Copy: Illegal software format" am facing many problems with current firmware "1.3.0.62 ". thanks
LinkedIN by Level 1
  • 23169 Views
  • 7 replies
Hello!   Is there some overview of the power consumption for the new SG250X-48P available?I am interested in some load scenario (idle, 1p conn., 1p poe conn., ..). Data sheet tells ~70W for system, thats for idle, or max. load w/o poe? Hope someone c...
hanna1 by Level 1
  • 911 Views
  • 0 replies
inter vlan communication is not happening. We have default vlan1 and created vlan10, we are getting internet, but we are not able to communicate between vlans.   Kindly someone hlep us on this.   Regards   Suresh
Hi Guys,    We are migrating our 4507 (IOS 12.2) to 6807 (IOS 15.5SY). We notice the qos command is different.   below is the existing command in 4507. qos map cos 5 to dscp 46qos ! interface GigabitEthernet3/1 switchport trunk encapsulation dot1q sw...
Hi,   have here a nativ 2*SG550XG-8F8T stack. Today I received this messages.   It looks like only unit 2 was rebooting, but the unit 1 master did not respond to pings, at least 1-2 minutes at this time. Therefore our HA disk appliance (iSCSI & NFS) ...
