08-12-2013 06:13 PM
The following settings reset to "False" on reboot.
I need them to persist across reboots.
Managed Address Config flag
Other Stateful Config flag
Only flash logs are:
2147483181 | 2013-May-02 09:59:54 | Error | %INIT-E-ApplErr: Errors occurred during initialization |
2147483414 | 2013-May-02 09:57:44 | Error | %MNG_DIAG-E-DIAGATINIT: Init: SNMPCenG_setVariable - init: Bad value for configuration item ipv6RouterAdvertTable, field rlIpv6RouterAdvertIsCurHopLimitUserConf igured |
2147483647 | 2013-May-02 09:57:44 | Error | %MNG_DIAG-E-DIAGATINIT: Init: SNMPCenG_setVariable - init: Bad value for configuration item ipv6RouterAdvertTable, field rlIpv6RouterAdvertIsCurHopLimitUserConf igured |
Solved! Go to Solution.
08-23-2013 02:39 PM
I have sent notification to the product management and escalation manager to investigate further. From the appearance, it seems to be a bug. However, there may be some sort of dependency we (you and I) may not be aware of. I'll let you know when I hear something back.
-Tom
Please mark answered for helpful posts
08-28-2013 08:43 PM
Hey, to follow up this, it has been reproduced in the lab. If you configure the feature through CLI it is persistent. This is limited to the GUI only.
-Tom
08-23-2013 10:21 AM
Hi Fratiani, I'm finding the same results, for the life of me I can't make that configuration stick.
-Tom
08-23-2013 11:31 AM
Ok, thanks for testing.
I have the same exact problem with my SonicWALL and I filed a report with them.
If you work for Cisco, do you think you could file a bug report?
I do not have support on my unit or I would do it.
Thanks.
08-23-2013 02:39 PM
-Tom
08-23-2013 06:19 PM
Thanks man
08-28-2013 08:43 PM
-Tom
