11-20-2012 01:38 PM
Can anyone tell me if the Cisco cable SFP-H10GB-ACU10M will work with the SG500 series switches for stacking? It's not addressed in the User Manual.
We're using the passive SFP-H10GB-CU5M now, but need a few more feet.
I really need a 5Gb connection, before anyone suggests a standard SFP connection.
-J
Solved! Go to Solution.
11-23-2012 01:37 PM
Hello Mr. Hickman,
You could use both kind of cables, SFP-H10GB-ACU10M or SFP-H10GB-CU5M on this device without problems.
Diego Rodriguez
Cisco network engineer
Thank you
11-23-2012 01:37 PM
Hello Mr. Hickman,
Diego Rodriguez
Thank you
09-09-2015 08:51 AM
Do you know if SFP-H10GB-ACU10M or SFP-H10GB-CU5M will work with Catalyst WS-C2960X-48LPS-L or not for Stacking purposes? The FlexStack module is very expensive for Catalyst 2960 and was wondering if I can use the same SFP twinax cables for stacking purposes on Catalyst 2960. Will the configuration remain the same on the Catalyst or will it be different?
Thank you!
11-27-2012 04:59 AM
Hi Jed,
Just to add to Juan post, for other folks that look at this posting.
Check out the table taken from the Sx500 series admin guide, it shows what to expect in terms of if the ports are in stacking mode or in networking mode..
You will note that the SFP-H10GB-CU5M or SFP-H10GB-CU3M cable in slot S3 or S4 connected between SG500 switches will sync up at 5Gig.
Thanks Juan for mentioning SFP-H10GB-ACU10M, I have no idea if this part has been validated, but thanks for the research.
Jed, I have attached the admin guide for your and other folks reference, It is freely available at cisco.com, but include it here as it has a really good section on stacking and mentions SFP connectivity options..
regards Dave
11-27-2012 07:19 AM
David,
Thank you for replying. I had used the admin guide for my initial research. However, it did not mention the 10 meter cable, which is the distance I need.
I'm currently using the 5 meter cables with some success. However, we're going to change to the ring topology now and need a longer cable for the back haul.
-Jed
11-27-2012 12:35 PM
Hi Jed,
If it works with no issue, I am not sure why the 10 meter cable was excluded from the SG500 admin guide.
Just keep the packaging for the SFP-H10GB-ACU10M, just in case it has to be returned to your distribution partner within the first 30 days.
Agreed, it seems a more cost effective alternative to 10GbE Short duistance SFP optics and fiber cables. :-)
have fun
regards Dave
03-16-2015 11:28 AM
Sorry to wake a dead thread, but can you post whether or not it worked for the benefit of the rest of us? Thank you!!!! :)
