07-09-2023 12:49 PM
We are using Cisco SG550X-24 (fw 2.5.0.83) at our remote office. A firewall report for Top Blocked Clients is showing SG550X-24 at the top with 5,004 hits every 24 hours. When looking at the firewall logs closer we are seeing the same pattern every min.
Switch management IP 10.1.1.2
Firewall 10.1.1.1
10.1.1.2 - > 10.1.1.1 HTTPS/TCP
10.1.1.2 - > 10.1.1.1 HTTP/TCP
10.1.1.2 - > 10.1.1.1 ICMP
The only reference to 10.1.1.1 in the switch config is "ip default-gateway 10.1.1.1"
Does anybody know why SG550X-24 is constantly sending HTTPS, HTTP and ICMP packets to the firewall?
07-09-2023 01:40 PM
Hi @net tech
Do you guys access the switch using web interface? or have any tools managing the switch remotely? That could be one reason
07-09-2023 04:21 PM
Yes, we access the switch via the WEB interface, but not every minute. PRTG is pinging the switch every 5 min and switch is sending sFlows to PRTG.
Wondering if the switch itself has some kind of keep alive check for the configured default gateway it has?
07-09-2023 05:48 PM - edited 07-09-2023 05:48 PM
I took a look on the switch config and documentation and I failed to find anything related to probe using any protocol.
I dont believe this is available. One test you could do is, using local access via console, disable the HTTP/HTTPS access and monitor the traffic.
07-09-2023 07:07 PM
Firewall logs
2023-07-09 22:02:56 Deny 10.1.1.2 10.1.1.1 https/tcp 40123 443 Management Firebox Denied 44 54 (Unhandled Internal Packet-00) proc_id="firewall" rc="101" msg_id="3000-0148" tcp_info="offset 6 S 1525599705 win 4" Traffic
2023-07-09 22:02:56 Deny 10.1.1.2 10.1.1.1 http/tcp 40123 80 Management Firebox tcp syn checking failed (expecting SYN packet for new TCP connection, but received ACK, FIN, or RST instead). 40 40 (Internal Policy) proc_id="firewall" rc="101" msg_id="3000-0148" tcp_info="offset 5 A 0 win 4" Traffic
2023-07-09 22:02:56 Deny 10.1.1.2 10.1.1.1 icmp Management Firebox Denied 40 39 (Unhandled Internal Packet-00) proc_id="firewall" rc="101" msg_id="3000-0148" Traffic
07-09-2023 07:10 PM
I should add that ICMP is a type 13 packet (Timestamp request)
Internet Control Message Protocol
Type: 13 (Timestamp request)
Code: 0
Checksum: 0xf0d2 [correct]
[Checksum Status: Good]
Identifier (BE): 557 (0x022d)
Identifier (LE): 11522 (0x2d02)
Sequence number (BE): 0 (0x0000)
Sequence number (LE): 0 (0x0000)
Originate timestamp: 0 (0 seconds after midnight UTC)
Receive timestamp: 0 (0 seconds after midnight UTC)
Transmit timestamp: 0 (0 seconds after midnight UTC)
