SGE2000 - Multiple IP address on the sameinterface
Carlos Bergia
Hi, anyone knows if there is a way to configure a secondary ip address (over the same address range) in a vlan interface on the SGE2000?
For example, I want Interface Vlan 10 on mw switch has 172.16.10.1/24 and 172.16.10.2/24. Is that possible? If I try I get an error message with a duplicate IP address error. On Catalyst switches it can be done, but on Small Bussiness?
Thanks a lot
Carlos
David Hornstein
Level 7
Level 7
Hi Carlos,
On all the small business L3 capable switches you can associate  one IPv4 address to each VLAN.
Or switch at layer 2 and allow the WAN router to have a secondary IP address.
regards Dave
