11-09-2009 07:19 AM
I am trying to mirror two ports on a SGE2000P switch. I have not set up any vlans but I keep getting an error that states Unknown value Port 4/g2 belongs to a vlan. My question is how do I get this error message when I have no vlans setup? Thank you for any help you can give me.
11-09-2009 10:39 AM
What firmware are you running? If you are running version 1 then you will need to upgrade to version 3. By default the SGE2000P model comes with 2 vlans and all ports are trunk. When you upgrade the firmware PAY CLOSE ATTENTION TO THE FIRMWARE INSTRUCTION. Once you upgrade firmware then retry to your task. Below is some steps how to preform port mirroring.
Step 1:
Access the Web based set-up page of the SGE2000 or SGE2000P.
Step 2:
Click Admin > Diagnostics > Port Mirroring. The Configuring Port Mirroring Page opens:
The Configuring Port Mirroring Page contains the following fields:
Step 3:
Click the Add button. The Add Port Mirroring Page opens:
The Add Port Mirroring Page contains the following fields:
Step 4:
Define the relevant fields.
Step 5:
Click Apply. Port mirroring is added, and the device is updated.
Hope this helps!
Jarocca Harper
11-09-2009 10:40 AM
Thank you for your help. But I needed to exclued the ports from the default vlan on the switch.
11-09-2009 02:22 PM
You can set all ports to access ports and assign ports to which vlan you would like.
Jarocca Harper
11-09-2009 02:23 PM
Or you can just turn the port off
