08-12-2013 04:43 AM
Hi!!
I want to share with you a problem that I found on this switch (Firmware is 3.0.2.0)
1) After i saving DHCP Relay Settings i reboot the switch and the settings are not saved, all others settings are ok but DHCP Relay settings are lost after reboot the switch.
2) Another problem is when I save setting copying Running to Startup the settings are not saved and the status is:
Bytes Transferred 0
Finished Copy Status
I must to copy Running to Backup and then Backup to Startup and the state is ok:
Transferred 4743 Bytes
anyone knows these problems? anyone can help me?
Thank you and sorry, but my english is so sad....
08-12-2013 05:13 AM
Hi Javier, please try a different internet browser or computer.
You can try other configuration changes such as creating a few vlans and try saving the configuration to see if the behavior is any different during the save process and the result after a reboot.
-Tom
Please mark answered for helpful posts
08-12-2013 07:43 AM
Thanks Tom!! All configurations are saved ok but not DHCP Relay settings. I am trying using Firefox and IE... same result!
Any idea?
