05-16-2011 07:15 AM
Hi there,
I have been trying, so far unsucessfully, to trigger backups to a TFTP server of our SGE201 switches. I have testesd TFTP backups via the web interface, and that does work. I need SNMP as I need a scriptable method to trgiger the backups on a regular schedule. I am running the SNMP query from a RedHat Linux server. So far I have the following query work out, but it is failing:
snmpset -v 1 -c COMMUNITY SWITCH.MGMT.IP.ADDRESS 1.3.6.1.4.1.9.6.1.101.87.2.1.7 i 2 1.3.6.1.4.1.9.6.1.101.87.2.1.8 i 3 1.3.6.1.4.1.9.6.1.101.87.2.1.9 a TFTP.SERVER.IP.ADDRESS 1.3.6.1.4.1.9.6.1.101.87.2.1.11 s FILENAME 1.3.6.1.4.1.9.6.1.101.87.2.1.17 i 4
The error I am getting is generic, and the same query failed on multiple switches running Software Version 3.0.0.18. The switch is set with the community having full SNMP-admin access from the server's IP address.
If anyone here has been able to run SNMP triggered backups and would be willing to post their query and/or software that would be greatly appreciated. Any other suggestions, comments or advice is equally welcome. Thank you for your time.
Solved! Go to Solution.
05-17-2011 11:29 AM
Jeff,
The procedure to download or upgrade the config via SNMP is as follows:
1) Download the MIB files we officially released from cisco.com
2) Compile the MIB files on MIB browser e.g. MG-SOFT, SilverCreek. Make sure there is no compilation errors.
3) Configure SNMPv2 or SNMPv3 accordingly on SGE2010 switch
4) Look for CISCOSBCopy.mib file.
The OID is SNMPv2-SMI::enterprises(1.3.6.1.4.1).cisco(9).otherEnterpise(6).ciscosb(1).odm1(101).CISCOSBCopy(87)
Using rlCopyTable(2), create an new entry on this particular table:
a. rlCopyRowStatus: 4 (createAndgo)
b. rlCopySourceLocation: 1 (local)
c. rlCopySourceIpAddress: 0.0.0.0
d. rlCopySourceUnitNumber: 1
e. rlCopySourceFileName: (blank)
f. rlCopySourceFileType: 3 (startup config), 2 is for running config
g. rlCopyDestinationLocation: 3 (tftp)
h. rlCopyDestinationIpAddress: 192.168.10.22 (tftp server ip)
i. rlCopyDestinationUnitNumber: 1
j. rlCopyDestinationFileName: 0x61:62:63 (in hex, abc)
By doing that, it should able to backup device startup config from device to remove tftp server.
05-17-2011 11:29 AM
Jeff,
05-19-2011 07:11 AM
Thank you,
Do you also have any particular recommendations for a command line Linux client to do this? I need something that is scriptable so it can be run against a number of switches at set intervals.
Edit:
For other's reference, the following works for me with snmpset, replace .999 with what ever ID you prefer:
snmpset -v 2c -c COMMUNITY -r 0 SWITCH.MGMT.IP.ADDRESS 1.3.6.1.4.1.9.6.1.101.87.2.1.11.999 s FILENAME 1.3.6.1.4.1.9.6.1.101.87.2.1.10.999 i 1 1.3.6.1.4.1.9.6.1.101.87.2.1.9.999 a TFTP.SERVER.IP.ADDRESS 1.3.6.1.4.1.9.6.1.101.87.2.1.8.999 i 3 1.3.6.1.4.1.9.6.1.101.87.2.1.7.999 i 2 1.3.6.1.4.1.9.6.1.101.87.2.1.5.999 i 1 1.3.6.1.4.1.9.6.1.101.87.2.1.4.999 a 0.0.0.0 1.3.6.1.4.1.9.6.1.101.87.2.1.3.999 i 1 1.3.6.1.4.1.9.6.1.101.87.2.1.17.999 i 4
Message was edited by: Jeff Whitehouse
05-25-2011 09:52 AM
Jeff,
Here's the info I got from my team. First and foremost, you don't need all of the parameters you showed, just the ones I here:
snmpset -v 2c -c public 10.5.233.57
1.3.6.1.4.1.9.6.1.101.87.2.1.17.1 i 4
1.3.6.1.4.1.9.6.1.101.87.2.1.3.1 i 1
1.3.6.1.4.1.9.6.1.101.87.2.1.7.1 i 2
1.3.6.1.4.1.9.6.1.101.87.2.1.8.1 i 3
1.3.6.1.4.1.9.6.1.10 1.87.2.1.9.1 a 10.5.71.7
1.3.6.1.4.1.9.6.1.101.87.2.1.11.1 s example1.txt
(here is "translation" for above -
Received Message Data {
Error-Status: noError,
Error-Index : 0,
Bindings {
CISCOSB-COPY-MIB:rlCopyRowStatus.1,
SNMPv2-TC:RowStatus,
"4"
CISCOSB-COPY-MIB:rlCopySourceLocation.1,
CISCOSB-COPY-MIB:RlCopyLocationType,
"1"
CISCOSB-COPY-MIB:rlCopySourceFileType.1,
CISCOSB-COPY-MIB:RlCopyFileType,
"2"
CISCOSB-COPY-MIB:rlCopyDestinationLocation.1,
"3"
CISCOSB-COPY-MIB:rlCopyDestinationIpAddress.1,
IpAddress,
"10.5.71.7"
CISCOSB-COPY-MIB:rlCopyDestinationFileName.1,
SNMPv2-TC:DisplayString,
"example1.txt"
05-10-2018 10:15 PM
hi sir,
.1.3.6.1.4.1.9.9.96.1.1.1.1.2. this snmp oid (COPY-CONFIG-COPY.MIB)working fine for core switch 2950 (ios version 12.1). but, .1.3.6.1.4.1.9.9.96.1.1.1.1.2. oid doesnot works in sg300 switch (ios version 1.3.0.1).
community changed RW , please tell me snmp mib oid for sg300 switch for backup configuration.
