SGE2010P Unresponsive, all ports lit
hugh_jeffner
Hello, I inherited a SGE2010P 48 port PoE switch (the dealer has since gone out of business).  The client on the premises where it was installed claimed there was a power outage this weekend.  When I arrived, all PoE devices were un-powered and all other connected devices had no network connectivity.
  • All 48 ports of the unit are lit green on both sides even if nothing was attached to them.
  • All the fans appear to be running
  • The status lights are all unlit.
  • The reset button does nothing, either held down continuously or held during boot
  • Web interface cannot be accessed
  • I haven't been able to attempt to access the console yet, but will try once the unit arrives on my desk
The lights and fans exhibit this behavior as soon as I power the unit.  Has anyone come across this failure mode before?  Sounds like its fried but I don't have much experience with Cisco.
7 Replies 7
Hi hugh_jeffner,
As you mentioned this is an inherited device do you know if you have a smartnet contract with this device? I can help you check and get this sorted. Hope to hear from you soon!
I successfully initiated an RMA
The only thing is if I try to track the status with this tool it says I am not authorized.
http://tools.cisco.com/support/serviceordertool/home.svo
I assume that is because I don't have a service contract
hugh_jeffner.
May i ask how many Cisco gear you have that has no service contract?
Happy to Serve!
Barry
Brandon Svec
Level 7
Level 7
There is no smartnet for smb devices like this and this model is not made or sold anymore.
It should still have a warranty though.  Possibly limited, lifetime.  I can't recall right now, but I did have and SGE switch go DOA a couple years ago and called smb support and they replaced it with a comparable SG switch.
Your best bet is to call SBSC support: http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
-- please remember to rate and mark answered helpful posts --
You can look at warranty info for that product here: http://www.cisco-servicefinder.com/warrantyfinder.aspx  It appears to have RTF (return to factory) so if it is really broke, they should let you send it back and then they send you a replacement.
Yeah I found that site and noticed the RTF, I think I will be pursuing that route.  Thanks.
hugh_jeffner
I just tested trying to connect via console got nothing.
