SLM2008 uPnP
robertgusztus
Hi All,
Can  you pls let me know how it is possible to enable uPnP on a SLM2008 switch?
I have a router (WRT320N, uPnP enabled) connected to port 1, a PC on port 2 and a PS3 on port 3, but it seems that the uPnP is not working throught the switch. I've enabled Enable IGMP Snooping, but unfortunately no success, I've only 1 VLAN.
Can you please advise, I'm really new in switch configurations... ?
Thank you,
Robert
nimusell
Hi Robert,
Thanks for your participation in the support community. My name is Nico Muselle from Cisco Sofia STAC.
I'm not sure whether the UPnP problem is due to the switch. Therefore, could you connect your PS3 directly to the WRT320N and verify if then it is working as expected ? There could be a problem in the UPnP handshake between the PS3 and the WRT320N which could prevent the PS3 to alter the port forwarding settings of the router.
Best regards,
Nico Muselle
Sr. Network Engineer - CCNA
