Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board from June 18th - July 18th. These dates are subject to change pending progress. This in...
CoreyP319 by Cisco Employee
  • 568 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5535 Views
  • 1 replies
  • 16 Helpful votes
Resolved! New to SGE2010P
I'm currently in the process of configuring my first Cisco SGE2010Pswitch and had a few questions as we typically use HP. I've created two VLAN's using the default as 192.168.26.1 on a /24 subnet. I then created a VLAN 10 with an IP of 192.168.1.1. I...
I am face with an issue where I cold not add a port to a dynamic vlan.The specific error is :Dynamic VLAN cannot be modified.The error log is below:Error codes from RAM2147483422 2010-Apr-28 14:37:06 Informational %VLAN-I-GVRPDelVlan: Dynamic VLAN V...
Hi AllI am trying to work out how to route between 7 vlans i have setup on my sg-300 in layer 3. when i look at the ip4 static routes i see that the managment vlan is listed as local but there are no other local interfaces. this is confusing me some ...
I have an slm2005 (amount other slm boxes) that has broken yet again.  It seems to boot and then all the lights flash but anything I plug into it won't light the associated port LED and I can't access the admin web page.  Where can I find out if it's...
wdaher000 by Level 1
  • 710 Views
  • 1 replies
I have a SF 200-24P and plugged in a MGBSX1.  I am logged into the web interface and see that nowhere does the switch acknoledge the mini-GBIC.  I can see that the GBIC is powered on.  If I plug the fiber in, the transceiver on the other end shows a ...
Have just had new fibre put into building. Am trying to connect with above.At one end the new switch is fine; at the other existing switch in software port shows as down despite having detected the fibre whilst physically all lit up as should be.Can'...
I'm looking for some assistance/guidance for IP helper configuration on a SF 302-08P. Currently, we are connecting a 302 to a Cisco 4507R-E chassis. Our VLANs are correctly configured on each switch (VLAN 1 for data, 2 for voice, 3 for management) an...
greggs123 by Level 1
  • 1254 Views
  • 1 replies
I'm trying to set up port descriptions on a 5 switch stack of 48 port SGE2010P switches.  Doing this through the Web GUI isexcruciatingly slow.  I tried doing it at the CLI with the 'desc' command, and that seems to work (if I do a show run the descr...
Hello, I recently bought a Cisco Switch SF 100-24, from where the Internet signal is spread to the whole house.That is, the Internet signal comes from the "street" via a cable/modem (from the cable company), andthe Cisco Switch is connected to this c...
Hi all,after having examined all the BPDUs transferred between the various switches by means of tcpdump and wireshark, I think I found the bug here which is really serious: a non-root SLM2008 sends BPDU frames where it steals the root's bridge ID and...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
