SMALL BUSINESS SWITCH SLM 2024
ISHAL
Hi , for some reason, i cannot access the switch via the web interface. i reset the switch to factory settings , and the same thing happens. i tried to access the switch via a diferrent pc and still the same, i would appreciate some help on this.
David Carr
Level 6
Level 6
Ishal,
Are you able to ping the device?
Have you changed the management vlan on the device by chance?
If all else fails have you Tried resetting the switch and plug directly into it and get into it with the default ip address of 192.168.1.254?
David Carr
Level 6
Level 6
Ishal,
Hi David
thanks for the reply. I have tried to ping the switch via the default ip and nothing happens, i also reset the switch, but still nothing.
Ishal,
Try isolating the switch from the network and reset it and see if you can access it.
I have the same problem. It used to work but now 192.168.1.254 gives nothing. And computer can't see aech other now.
