SNTP not working on Cisco SG220
oceanswitch
I'm trying to make SNTP work on a Cisco SG220 switch by using a NTP server pool ("0.europe.pool.ntp.org"). When I put the IP address of a NTP server in that pool, it works fine. But when I put the proper FQDN to the pool, the system time does not get in sync.
For your reference, I have gateway and DNS addresses configured properly (ping for "0.europe.pool.ntp.org" succeeds).
Any ideas?
marce1000
 - For starters try to configure a 'direct ip address' only from 0.europe.pool.ntp.org  , and check if that works,
 M.
Yeah by putting an IP address from the pool, it works fine. And name resolution seems to work fine, but SNTP seems to fail at using DNS.
 - This could be a bug or restriction , depending on how it is viewed , but you can add the resolving addresses as multiple sntp servers too ; that then does not include future ip address changes for the service ; but it can be argued that this can be seen as enhancing security; for instance IOS when configuring a NTP server ,will immediately resolve to the first IP address found in the running config for similar reasons ,
 M.
johnmolina
Hi there,
I've faced a similar issue before. It sounds like your switch might be having trouble resolving the FQDN to an IP address consistently. Here are a few things to try:
Ensure that your DNS settings on the switch are correct and that it can consistently resolve other FQDNs.
Sometimes switches have a preference for IP addresses over FQDNs for NTP. You might want to stick with a specific IP address if it's working fine.
Try using a different NTP server pool or a different time server altogether to see if that resolves the issue.
If the problem persists, consider updating the firmware of your switch, as this might be a known issue that has been fixed in a newer version.
