srw2008 powe consumption
Dear All,
What is max power consumption of SRW2008, SRW2008P, SRW2008MP switch?
There is nothing about it in the DS or UG.
Best Regards,
Lukasz
dasasse
Hello Lukasz,
The power consumption of all 3 devices is around 17 watt, without PoE.
So the max with PoE (depending on the attached devices) would be for the
SRW2008        around 17W
SRW2008P          = 17W + (4x15W)                             around 80W
SRW2008MP       = 17W + (8x15W)                             around 140W
Of course these values are just correct when the PoE devices are really using the maximum possible power provided.
I hope this helps you.
Daniel
Hi Daniel,
Thank you for information, this is what we were looking for.
BR,
Lukasz
