SSH Weak Key Exchange Algorithms Enabled
Hi Guys,
I have a Cisco SF300 switch. We have done VAPT and found that vulnerability "SSH Weak Key Exchange Algorithms Enabled". I need to disable this. Please suggest how to resolve this issue. How i can login to switch via ssh more securley?
Rakesh
6 Replies 6
Mark Elsen
         - Use latest firmware for the device , (if not yet done)  , check if that can help.
 M.
The current running Firmware version is 1.4.11.5 and it is the latest firmware.
balaji.bandi
As per the shared link, there is no workaround that addresses this vulnerability.
Is there any alternate way to access the switch via SSH more securely? Is there any more option in ssh authentication?
I got this document on the internet, public key authentication for ssh on cisco switches.
https://helpdeskgeek.com/how-to/enable-public-key-authentication-ssh-cisco-sg300-switches/
