03-10-2021 04:08 AM
My network has the following VLANs:
- VLAN 1: 172.16.10.0
- VLAN 10: 192.168.2.0
- VLAN 20: 10.10.10.0
- VLAN 30: 192.168.4.0
- VLAN 40: 192.168.5.0
- VLAN 50: 192.168.6.0
- VLAN 60: 192.168.7.0
- VLAN 70: 192.168.8.0
Currently I cannot ping the PCs in the VLANs, while I have routed the VLANs together
Solved! Go to Solution.
03-10-2021 06:56 PM - edited 03-10-2021 07:06 PM
- PC0: VLAN10 - PC1: VLAN30 - I cannot ping from PC0 to PC1 - I have "ip routing" enabled on SWCORE.Do I have to route each VLAN through the connection
03-10-2021 04:22 AM
As per the Attached configuration - why all the ports are in Trunk mode? make sure they are in Access port ( respected VLAN)
make sure you enable ip routing on your SWCORE
if this switch acting as Layer 3 and send out all traffic you need to add ip route entry instead of (ip default-gateway 172.16.20.1)
Try disable macro
no macro description switch
no macro auto smartport dynamic_type switch
on the SWVLAN1 config all ports belong to Access VLAN 10
Tests and input required :
1. what is the PC IP address ? what VLAN ? or what port it is connected ?
2. are you able to ping own PC gateway IP address ?
3. waht VLAN IP you try to ping ?
03-10-2021 07:04 PM
