Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3658 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5343 Views
  • 1 replies
  • 16 Helpful votes
When plugging in a Ruckus R550 or SG350 switch on a PoE port  LLDP and CDP will negotiate maximum power the port can provide be it 60W or 30W.  Only way to "fix" this issue is to turn off the LLDP power setting or the PoE of the port. Issue is after ...
MikeSON by Level 1
  • 2257 Views
  • 2 replies
Hello, How we can get the information presented in this image through command line (the target switch is cisco sf302-08pp, and the table is RMON Alarm data) we found "show rmon alarm-table" and "show rmon alarm number" commands for this issue, but st...
Good morning  I have a  single SG350 switch connected to a Modem-route. I want to disconnect the router from the switch and that all PC's communicate with each other using the switch, as they do not require Internet connectivity. I wonder if that can...
Okami11 by Level 1
  • 1557 Views
  • 2 replies
 Hello all. I have two SG350XG-24F (fw ver 2.3.0.130) units in a stack ad they're uplinked to a core device via a port-channel. I wanted to enable sFlow on each of the member interfaces to get an idea of traffic on the individual units. So I set the ...
WGL_BK by Level 1
  • 722 Views
  • 0 replies
 I need urgent Help: How to configure SF300 24Port Switch Bandwidth QoS. I was purchased new 2 cisco SF300 Switch, one is Layer 3 Router mode another is Layer 2 Switch.i was configure all port QoS, but how to configure port Fa11 for my 20 WAP user's ...
Hi everyone,I just purchased a CSB250 MultiLayer Switch, out of the box in VLAN 1 internet routes through all the ports. I would like my AP's in a separate VLAN and route the internet on both vlans. I setup my Switch (see attached file) through the C...
dewin by Level 1
  • 963 Views
  • 3 replies
  • 5 Helpful votes
Hi, Everyone,I am from ASIA my small network deployment for my ISP Business here is details design showing. Now it's design Private IP address later i am deployment with Public address APNIC!If I am Success about this Networking IP address is 192.168...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
