switch SG550X prom
syedehsan
Dear Sir,
Can I get details about :-
Reboot the switch by unplugging the power cord. You will see a prompt during boot right after the Cisco logo made out of #s that says “Autoboot in 2 seconds – press RETURN or Esc. to abort and enter prom.”
[1] Download Software
[2] Erase Flash File
[3] Password Recovery Procedure
[4] Set Terminal Baud-Rate
[5] Stack Menu
[6] System Mode menu
[7] Back
details for option [1] and [2]
can i download firmware using option [1]
can I reset factory defaults by using option [2]
Kindly give me the details for the reset factory default.
My reset switch is not working for the cisco switch sg550x and the switch is continuously restarting what to do to get the factory defaults.
balaji.bandi
sir neither i am getting GUI nor CLI prompt before that it gets restart.
Is there any other method to transfer image,  saw there is an option xmodem but I do not know how to transfer with this option.
FOLLOW THIS THREAD
BB
