SX350X-24F-K9-UK recommended cables/transceivers
brucecraig
I'm sure this is a very simple question but i'm new to using 10gbe SPF+
I have a SX350X-24F-K9-UK. 4 SFP ports are Combo ports.
I need to connect a Mellanox ConnectX-3 Pro Ethernet Adapter & Intel(R) Ethernet 10G 4P X520/I350 rNDC  to the switch. Both 10gbe Copper Server NIC's
What cables are recommended to do this or do I need to use a Cisco Transceiver on the switch side and a Generic Transceiver on the Card side connected via cat6a?
Bruce
balaji.bandi
SX350X-24F-K9-UK  - as per the product do have multi port on the up link side - which has copper and optic you can use directly to server RJ45 link - but check with Cisco partner before buying.
Other options :
If the server has copper NIC you need  Optic SFP-10G-T-X (unfortunately it does show show as comparable with this switch - may be not update data here)
Look at the matrix - SFP-10G-T-X  - cable and distance.
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c78-455693.html
Other suggestion see if server can get Optic SFP, so you can use 10-SR SFP to connect to server
BB
