Trouble with SF 300-24P 24-Port 10/100 PoE
Igor Yakimchuk
Good day.
I connect to switch Access Point, configure port on switch which vlan work on this port. But after reboot AP my config for this port delete and have other config where vlan 1 untagged, and allow all other vlan. But in my cinfig allow 3vlan: untagged 100, and tagged 113, 999.
How to solve this problem?
Tom Watts
hi Igor, you need to save the running config to the start up config, otherwise a reboot will drop any changes made to the switch.
When you make a change to the switch, on the top right of your browser there is a blinking button to save, click this and save the run config to start up.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
all problems were because of configure smartports. Edit this config and all ok :). Thanks
Ivan Perino
I have a problem with  a SF300-24 24-Port 10/100 Managed Switch. One of the interfaces loses the vlan configuratiuon whet the switch restarts. Off course I saved the changes.
Hi Igor,
Adding to what Tom mentioned, I would suggest you to download startup configuration and running configuration and compare those two.
Aleksandra
