Troubles with trunking on SG switch
ehermansen
I am trying to connect two SG switches together with trunk and there are some issues with some of the VLANS.
Two of the VLANS are working; 10 and 99 but the rest of them are not working.
The models of the switch:
One is: CBS350-24S-4G 24-Port Gigabit SFP Managed Switch
and the other one is SG350XG-24F 24-Port switch
Active-image: flash://system/images/image1.bin
Version: 2.0.0.73
Version: 3.1.1.7
Config switch 1:
vlan database
vlan 10,20,30,40,50,90,99
Bolig#sh run int gig 27
interface GigabitEthernet27
spanning-tree link-type point-to-point
switchport mode trunk
switchport trunk native vlan 90
switchport trunk allowed vlan 1-2,10,20,30,40,50,90,97-99
Bolig#sh interfaces switchport gig 27
S-VLAN Ethernet Type: 0x8100 (802.1q)
VLAN Mapping Tunnel L2 protocols Global CoS: 5
Switchport: enable
Administrative Mode: trunk
Operational Mode: up
Access Mode VLAN: 1
Access Multicast TV VLAN: none
Trunking Native Mode VLAN: 90
Trunking VLANs: 1,10,20,30,40,50,90,99
2,97-98 (Inactive)
General PVID: 1
General VLANs: none
General Egress Tagged VLANs: none
General Forbidden VLANs: none
General Ingress Filtering: enabled
General Acceptable Frame Type: all
General GVRP status: disabled
Customer Mode VLAN: none
Customer Multicast TV VLANs: none
Private-vlan promiscuous-association primary VLAN: none
Private-vlan promiscuous-association Secondary VLANs: none
Private-vlan host-association primary VLAN: none
Private-vlan host-association Secondary VLAN: none
Config switch 2
vlan database
vlan 2,10,20,30,40,50,90,97-99
port22
interface tengigabitethernet1/0/22
macro description switch
!next command is internal.
macro auto smartport dynamic_type switch
G350XG-24F-SW1#sh interfaces switchport TengigabitEthernet 1/0/22
Gathering information...
Switchport: enable
Access Mode VLAN: 1
Trunking VLANs: 1-2,10,20,30,40,50,90,97-99
3-9,11-19,21-29,31-39,41-49,51-89,91-96,100-4094
(Inactive)
General PVID: 1
General VLANs: none
Classification rules:
Classification type Group ID VLAN ID
