Trunk port changes assigned VLANs spontaneously
igorlazo99
I have problem with GE2 port VLAN membership in trunk mode.
When I set GE2 port as a trunk for VLAN 11 tagged, VLAN 48 tagged
and VLAN 666 untagged+PVID, it stays so only untill reboot.
After reboot there are 11, 48 and 666 tagged, while VLAN 1
untagged+PVID. Everything works somehow, but there are warnings.
Default VLAN 11. The other side is 2960G with no vtp on port
and vtp is globally off.
Thank you
SF 200-24 24-Port 10/100 Smart Switch
Model Description:  24-Port 10/100 Smart Switch  Firmware Version:  1.1.1.8
Serial Number:  DNI15330085  Firmware MD5 Checksum:  0b73c744e12a6f93c711867b1188736e
PID VID:  SLM224GT V01  Boot Version:  1.0.0.1
  Boot MD5 Checksum:  81359f6e6c7e640b53df27c4f05b8d60
  Locale:  en-US
  Language Version:  1.1.1.6
  Language MD5 Checksum:  N/A
jasbryan
Level 6
Level 6
Igor,
Might need to call Cisco Small Business Support Center @ 1-866-606-1866 and open a support case for your issue.
http://www.cisco.com/en/US/partner/support/tsd_cisco_small_business_support_center_contacts.html
Jasbryan
David Hornstein
Level 7
Level 7
Hi Igor
Just out of interest, I see no mention that you saved the configuration in your problem description.
As the administrators guide says on page 30,  Configurations will be lost if not saved.
Just in case you didn't save your configuration, here is a 6 minute video that shows,  in the last minute,  how to save the configuration of a 300 series switch, but it should be identical for a 200 series product..
https://cisco.webex.com/ciscosales/lsr.php?AT=pb&SP=MC&rID=56220782&rKey=5fc47a1c7b566b8c
or try from the GUI
Click Administration > File Management > Copy/Save Configuration
Copy the running configuration to the startup configuration.
If you have saved your configuration but still lose VLAN assignment, yes please follow the advice in the previous posting.
regards Dave
