Trunk Problem
momobhai
Hi, I'm a beginner using cisco switch for VLANs.
I've configured a switch with 4 VLANs for data/AP/CCTV/IP phone
VLAN 2,3,4,5
when I pull out and reinsert network cables, these ports configured for IP phones turn from access GEs  to the trunk
how can I prevent this?
thanks
marce1000
 - Disable the Auto Smartport feature on the involved ports : https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/content/en/us/td/docs/switches/lan/catalyst9200/software/release/16-12/configuration_guide/int_hw/b_1612_int_and_hw_9200_cg/configuring_auto_smartports.html.xml#:~:text=To%20disable%20Auto....
 M.
balaji.bandi
what model of the switch here? is they are the SG series.
If you do not know how to use smart port usage, then as suggested go to the traditional way by disabling the smart port good move.
BB
Jitendra Kumar
Disable the DTP on the port,s if getting an issue and disable the auto-negotiation if required..
for checking DTP below is the command
#show dtp interface gigabitEthernet 0/0
Jitendra
