Trying to understand difference between CBS250 and CBS350 lines of switches.
RodgerB
My company has deployed a lot of SG350, SG350X, and SG550X switches in the past (we are a A/V integrator).  I am trying to grasp the fundamental differences between these 2 new lines of switches (CBS250 vs. CBS350).
I see the CBS250 line has 10G SFP options now, and wondring what I am leaving on the table if I start building networks from the CBS250 line of options.
I am HAPPY to read a white paper on the topic, but after an hour looking through the cisco.com website I have yet to find any information specific to this question.  TIA
16 Replies 16
Update:
It works, I got two Cisco CBS250-24P-4X interconnected, each with one single 10Gtek SFP+ SR Multimode Modul "AXS85-192-M3” in SFP+ port #1, plus compatible LC-LC OM3 50/125 multimode fiber patch cable.
Reason (I guess): Both switches are still unchanged on DHCP, BUT got same “static” IP-addresses every day beforehand via new DHCP-router!
You can close my request!
Thanks & regards
Rudi
Martin Aleksandrov
Hello Rodger,
That is a good question to note.
The CBS250 series are Layer 2 and basic L3 switches whereas CBS350 series are advanced Layer 3 switches. That means we have incorporated in CBS350 a certain number of enhancements and value-added features in terms of security, manageability and PoE budget compared to CBS250. From a functionality standpoint, key differentiators are PoE budget, Stacking and some advanced security features like BPDU guard, Dynamic ARP inspection, sFlow, RSPAN, etc.
Based on your use case as an A/V integrator, I suggest you won't need those security enhancements but will be more focused on the management and PoE options and least but not last the price. That being said and if the PoE budget satisfies your needs we would recommend the CBS250 series switches. Also do not forget you get the new Cisco Business Dashboard embedded within the switches which as part of the Cisco Business Dashboard app give you a great opportunity for centralized single-pane-of-glass view, monitoring and management solution to your or customer's network. With Cisco Business Dashboard (free for download) you can manage up to 25 devices free of charge with no license.
More detailed information about the product and how to set up you can find in the following links:
Cisco Business Dashboard (CBD)
https://www.cisco.com/c/en/us/products/cloud-systems-management/business-dashboard/index.html
CBS250/CBS350
https://www.cisco.com/c/en/us/products/collateral/switches/business-250-series-smart-switches/nb-06-bus-switch-trans-guide-cte-en.html (scroll at the end to link to the datasheets)
Martin
More infor
