08-08-2013 01:57 AM
Below is my switch detail information,
System Description: 24-Port Gigabit PoE with 4-Port 10-Gigabit Stackable Managed Switch
Firmware Version (Active Image): 1.2.0.81
Firmware Version (Non-active): 1.2.9.44
Boot Version: 1.2.0.12
Q1: upgrade FW to sx500_fw-12944.ros and active image-2 then reboot switch.
after switch reboot, GUI still show Active Image is 1.2.0.81.
Q2. when try to upgrade FW:Sx500_FW_1.3.0.62.ros. GUI show FW format error.
I have try to upgrade from HTTP/HTTPS and TFTP, but got same result.
thanks.
Solved! Go to Solution.
08-09-2013 12:20 AM
Hi Singow,
Could you please open a case with SBSC and ask them to escalate the case to L2? We do have a firmware version 1.2.0.83 that fixes your upgrade issue.
Thank you,
Marcelo
08-08-2013 06:48 AM
Hello singow hsu,
When you go to Administration > File Management > Active Image and you select the non-active image to be the actove one, what does the Active Image After Reboot and Active Image Version Number After Reboot fields display? Also, I know this is basic question, but do you click Apply before rebooting?
For your Q2, can you type out exactly what the error is showing?
08-08-2013 07:16 AM
Hello Joshua Roeder,
of course, I click Apply before rebooting.
and the firmware info after rebooting is:
one thing i don't understand is i have to set my default password again when login to GUI after reboot.
error messgae for my Q2:
Upgrade/Backup Firmware/Language |
thanks again.
08-08-2013 07:21 AM
Hi Singow, this switch should have never shipped with 1.2.0.81. I'd recommend you call the SBSC and ask them to fix it or RMA the switch.
-Tom
Please mark answered for helpful posts
08-09-2013 12:20 AM
Hi Singow,
Thank you,
Marcelo
08-09-2013 12:53 AM
Hi Marcelo, I have upgrade the firmware first to 1.2.0.83. and after that , everything is ok.
Thank you.
05-13-2015 04:17 PM
Hi singow_hsu,
is it possible for you to send me this firmware? I'm having the same issue that you had. I can't switch firmware or upgrade my switch.
Thanks.
Jimmy
